Thread: tow bar photo
    Oct 2007
    lincolnshire
    Default tow bar photo
    has anyone got a in the boot photo of there tow bar fitting please
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    it just so happen's i have mate, give me 5 to upload my pic's
    Midlands Mod Shop - NFFC.
    scotland
    why do u need a pic
    the plate on the fixing sits onto the boot floor ( after the insulation has been cut out)
    cant be seen after carpet has been replaced
    Trim : Get a
    here you go matey, taken while finishing mine off, there are small dimples in the floor pan where you are to drill through into the chassis leg area/rear panel, dead easy realy just make sure once you have drilled them and put the sleve's in you don't knock the sleves over into the chassis leg
    Oct 2007
    lincolnshire
    my brinks tow bar has a large plate that goes under the car i then have 4 bolts 2 either side, it has a large plate and a smaller plate and i would just like to know weather the large plate goes in the boot or under the car.
    scotland
    Quote Originally Posted by graememk View Post
    does the plate not come attatched to the bolts?
    mine did , therefore it goes through the boot and the nuts attatch to the underside .
    as per pics above
    Hertfordshire
    Quote Originally Posted by ditchp View Post
    taken while finishing mine off.
    Hey m8, was any sound deadning removed from the boot floor, because it doesn't look like it was in that pic.
    Oct 2007
    lincolnshire
    this is what i have, the plates with the bolts going through them should the larger plate be ontop or below ?
    Hertfordshire
    Yep, definitely, large plate on top, onto the boot floor, and don’t forget to remove the sound deadening from directly under the plates.
    Trim : Get a
    Quote Originally Posted by Green Growler View Post
    i cut around the plate after first propper pic, got most of it off bar some small bit's
  1. photo
    By kev77 in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2010, 16:41
  2. Photo Help
    By corsa_si in forum Quick Photo Album
    Last Post: 30th October 2009, 14:24
  3. Photo
    By ed taylor in forum General Chat
    Last Post: 22nd November 2007, 21:35
  4. photo of my car?
    By leroy in forum General Chat
    Last Post: 5th April 2006, 09:25
  5. Not exactly a Photo ........
    By AJA in forum Quick Photo Album
    Last Post: 12th December 2005, 20:23
