Results 1 to 10 of 13
Thread: Speedo Calibration
    scotland
    Default Speedo Calibration
    Hi Folks,
    I changed my front tyres to 225/45/17 on standard sri facelift rims.
    I think my speedo is well and truly out. Is it possible to get a speedo recalibrated from the local stealer??
    Or should I go back to the 215/50/17 dont like the extra mileage the smaller tyres are showing up in the car!!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I think I remember someone saying there was a setting that could be changed by Tech2. Maybe someone will confirm this
    Full Member Big Sig's Avatar
    Its such a small amount its not worth bothering with. But you can get it done if you want.
    Regular Member lilangel's Avatar
    bucks
    i am running this size and my pogo alert says i am goin about 3 miles les than speedo says
    Jul 2006
    The difference really is barely noticeable. IIRC it's the difference between reading 2mph over or 3mph over at 60mph. If you're that bothered, change back to 215/50 tyres...
    Quote Originally Posted by oxenburger View Post
    Easiest way is like this
    Travel at 60mph
    One mile should take you exactly one minute
    My local council (cough, cough, spoke to the "right person") were kind enough to supply me with the locations of two roads that are ideal for this
    One of the roads is exactly half a mile between two junctions, so travelling at 30mph this also takes me one minute
    It actually takes about 61 seconds, and I've tried it in both directions!
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    Check this site: http://www.tyresave.co.uk/tyresize.html
    Your new tyres are about 2% smaller so it will add 2% to your mileage, that's a reading of 20,400 miles after 20,000 actual miles. Not much really.
    And it should indicate 1.2 mph faster than you are actually doing at 60 mph.
    [Ex]Admin Duncan's Avatar
    As parapaul said it'll only read about 1mph more under at 60-70mph.
    If it bothers you then yes you can get it Tech 2d to correct it. Personally I wouldn't waste the money for the difference the 225/45/17s make to the reading.
    Heres another idea
    With so many local authorities having now installed "Your speed is" signs, use that!
    There seem to be quite a few near me now and have tested them at an indicated 30 and 40mph, and all but one are fairly close
    There is one in Rosyth that seems to be out by "quite a bit"
    I've driven towards this one at 30mph and it displays either 25 or 26mph, yet the one in the other direction is almost spot on
    Regular Member Whoosh's Avatar
    North East
    here will give you the exact % difference
  1. Facts about injector calibration figures.
    By nutron in forum Diesel Engine related
    Last Post: 13th December 2012, 00:40
  2. SatNav Lost / Out of calibration
    By Syvlie in forum Electrical & ICE (including SatNav)
    Last Post: 20th April 2010, 22:21
  3. SAS re-calibration cost
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2009, 19:30
  4. Speedo Calibration
    By chrisf70 in forum General Chat
    Last Post: 2nd December 2008, 11:20
  5. BC calibration
    By Islander in forum Electrical & ICE (including SatNav)
    Last Post: 19th May 2007, 17:43
vectra c nastaveni tachometru
