Results 1 to 10 of 13
Thread: Rear wiper problem
    Regular Member spatch's Avatar
    Aug 2007
    Kent
    Default Rear wiper problem
    Hi,
    My rear wiper is dicking around. When the screen is wet it operates ok, but when it is drier it often sticks, then a moment later moves etc until fully home. First time I noticed it the engine was not running, but it also does it with the engine running.
    I think it is probably the motor, any comments welcome before I start removing the trim.
    Cheers,
    Regular Member signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    DITTO ...got the same problem myself
    Aug 2007
    Kent
    No comments as to whether the first investigation should be the motor?
    Regular Member m_r_shaw's Avatar
    Sunny Waterloo, just outside Liverpool.....
    ^^^^C'mon lads......
    my 04' estate has a noisy rear motor too....makes a scratching sound, almost like it's got grit caught underneath the blade so I too suspect the motor?????
    Aug 2007
    Kent
    Looks like I will have to go it alone! I think I will have a look at the motor.
    Aug 2007
    Kent
    OK, had a look and got panel off but need a female torx drive to remove motor. Will have to take a trip to Halfords or quick surf on net for one of these.
    Cheers,
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    Never had experience of rear motors packing up. So no useful input from me but at a guess if it works ok when wet.. ie less resistance for the motor to move the wiper, and sticks, stops starts when dry you could well be on the right track.. Let us know how you get on...
    Aug 2007
    Kent
    Jobs a good'un!!
    Took the motor off (you will need an E8 female torx drive), split the casing and cleaned it all out. The contacts (and disc) were quite dirty and took a fair bit of polishing to get them back to clean metal. The mating drive cogs on the wiper drive shaft were also dirty and did not run very smoothly at all.
    In any case, once regreased and reassembled it works fine again.
    Cheers,
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    Nice going there.. One for future referal for others
    Edinburgh/outskirts
    Mileage : 38000
    Know what im doing Weds ..cheers my friend
  1. Wiper Electrical Problem? (Not sticking or cold weather problem)
  2. Rear Wiper Problem
    By Richard Bignell in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2012, 20:17
  3. Wiper Problem
    By djh82uk in forum Electrical & ICE (including SatNav)
    Last Post: 14th August 2011, 18:07
  4. Rear Wiper Problem.
    By arnie_barney in forum Introduce yourself.
    Last Post: 5th February 2010, 00:59
  5. Another wiper problem!
    By Taffyopel in forum Electrical & ICE (including SatNav)
    Last Post: 9th January 2009, 20:34
opel signum rear wiper problem
