Thread: Body Control Module ?
    Regular Member 900ss's Avatar
    May 2008
    Bucks
    Default Body Control Module ?
    Can someone confirm if you can reset (reuse) a BCM from one car to another?
    I asked at the local vx dealers but was told they donít know until "they try" as they only fit new
    Feb 2007
    Glasgow
    Yep, should be reset with Tech2 when removing the module, (you might be able to do it later if you have the security code, though).
    May 2008
    Bucks
    No, all I have is a used unit. Same part numbers but no code to match it.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    hi fella, you could contact these for advise, as i have sent them my airbag module http://www.crash-data.co.uk/ hth
    May 2008
    Bucks
    Cheers Glynn but its not the airbag module at fault.
    This is the control modue that sits in the nsf kick well behind the glove box.
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    Dunno if u can which is why i advised they were all reset before the event... Only way now mate is to plug it in and get someone to try for you... Pity u aint nearer or i could have tried.
    May 2008
    Bucks
    Quote Originally Posted by plasma View Post
    Cheers, yep I've already fitted it but lost the c/locking in doing so. Everything seems to work apart from that.
    Engine fan and temp gauge dont work either, but I believe that could be the clox at fault?
    Looks like a trip to the dealers is on the cards then
    May 2008
    Bucks
    Quick update and after £89 lighter it seems they cant reprogram them, or atleast not without the matching sec code (which I dont have)
    Still cars rebooked in next wk for a new BCM @ a knock down price of £330 fitted
    BCM is £140 + vat and the rest is all labour
    **** me I didnt realise plugging in a computer was so expensive
  1. body module?
    By *enery* in forum Electrical & ICE (including SatNav)
    Last Post: 18th May 2012, 09:20
  2. Body Control Module
    By 1973andi in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2011, 23:24
  3. Body control module ( bcm ) HELP
    By clive3373 in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2009, 13:54
  4. Body Control Module
    By bnam in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2009, 17:50
  5. GSI Body Control Module?
    By 900ss in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2009, 08:56
vectra c brand new body module
modul bcm vectra c
vectra bcm
body control module vauxhall
body control module vectra 07
body control module vectra c
vectra bcm reset
fitting a vectra c body control module
vauxhal vectra c body control module price
vectra c body control module location
vauxhall vectra body control module problems
