Thread: EGR Valve 2.0 DTI
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    confused EGR Valve 2.0 DTI
    I've seen a lot about cleaning the EGR valve, but I'm not sure where it lives or how to clean the thing. Could someone enlighten me with photo's. I've seen a "How to", but that relates to the 1.9 CDTI, but has anyone got info regards the 2.0 Dti engine ???
    Many thanks in advance.
    Regular Member signum junkie's Avatar
    Edinburgh
    Hi m8 I've been told that EGR is dif on our cars so doesn't suffer from same fault. If I am wrong then someone will be along to correct me soon
    they do coke up, but not at all at the same rate as the CDTi's.. ( bigger port so less of a problem) ..if it's running fine then don't panic about it..it's not a massive job to do when the time comes..
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    Ahhhh! Finaly found a post on the DTI EGR...
    But not much info here so BuMp^
    Someone mite see this and hellp. Because once i know where to look and a little about it am gonna whip that little monster out and give it a scrub!
    I think its a dirty little ******!
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    HI andy its simple just pull the 4 torx screws out take off the inlet pipe and stsrt cleaning ,you will see for yourself, no replacement gaskets needed no tech 2 needed and do the airbox mod
  1. Brake servo Valve (one way valve)
  2. Replies: 6
    Last Post: 29th July 2012, 13:52
  3. Egr valve, swirl valve problems etc..
  4. EGR valve / Swirl valve
    By SwavGav85 in forum Engine & Drivetrain
    Last Post: 5th January 2009, 17:17
  5. EGR valve and Swirl Valve
    By TUX-VECTRA in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2007, 00:43
