Thread: X Box 360 Wireless Connection
    Regular Member Perry's Avatar
    Watford Herts
    Default X Box 360 Wireless Connection
    Quick question really, it's a pain running a lead from the X box to my router now I have moved house, my router is a wireless netgear and I have a netgear usb wireless dongle thing as well. Can I plug this into the X box to make the connection wireless or do I need the actual X box wireless thing that plugs in?
    Pretty sure you need the proper x box wireless adaptor. They are not cheap either
    Watford Herts
    ok then different approach maybe but wire the wireless router into the x box and use the dongle on the pc??
    Yep you can do that. You can also run your pc wireless and plug your xbox into your PC. Don't ask me how though
    Quote Originally Posted by Perry View Post
    Yep, you could do that if your router can be positioned such that you can still plug it onto the phone/cable socket.
    Other option instead of the Xbox wireless adapter (although I would recommend it as it really is plug and play, very small, attaches onto the console itself on the back, needs no power supply and is all controlled from the console) is what's called an Ethernet bridge. Basically it's a little box that plugs into the Ethernet socket on the Xbox and then links wirelessly to your router. A bit cheaper than the Xbox thing but TBH more faff. It'll need a power supply and to set it up you'll initially need to plug it into a PC as you access it through a web browser interface.
    I know they're a wee bit pricey for what they are, but the Xbox one is just so simple and less faff.
    May 2007
    south ockendon
    have a look on ebay mate, seen a few go on there for 45/50 quid, its not a lot cheaper but anything is better then nothing
  1. USB Connection?
    By romit2001 in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2008, 20:03
  2. wireless connection keeps dropping ???
    By deano1 in forum General Chat
    Last Post: 25th July 2008, 14:44
  3. Please Help: Wireless Connection keeps dropping
    By Dunc in forum General Chat
    Last Post: 18th July 2008, 16:32
  4. Is this the VDA connection
    By caravaner-tony in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2008, 22:14
  5. Replies: 12
    Last Post: 29th November 2006, 10:17
