Results 1 to 10 of 13
Thread: ECU Light & Fault Code help!
    Sutton Coldfield
    Exclamation ECU Light & Fault Code help!
    Hi All. I need help with my Vectra ('04 Club DTi 2.0)
    Bought the car in March and now have the ECU Light on the dash most of the time. Initially it came on very rarely, intermittently either driving around town or cruising on the motorway. no particular link, and no drop in performance or noises.
    Over the summer it came on more often, and now it is warmer (kind of!) it is on 95% of the time.
    Took it to the VX garage in Cannock and this is the result of the diagnostic test:
    "Engine Management Light On
    Read T/C with diagnostics tester. With TECH 2 and check with guided
    CHECKED VEHICLE WITH TECH 2
    P1483, 54, FAN CONTROL 3 CIRCUIT OPEN,
    PRESENT, FUSES FE35 AND 36 OK
    NEED MORE TIME FOR WIRING CHECKS, COOLANT LEVELS OK
    Print out the protocol list for diagnostics."
    I had two people actually suck air through their teeth at me (never had that before! Thought it was a myth!) and say "i hope its not the ECU itself" and then get quotes of £1600+VAT for me to worry over.
    Has anyone seen this before? common fault? Any help would be warmly welcomed!
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    P1483 - Engine Cooling System Performance
    Is this helpful?
    Full Member Big Sig's Avatar
    Do the fans actually start and stop?
    fan control module?..
    Sutton Coldfield
    ah thanks all, very interesting. I did see the code list but my laptop crashed every time it opened )
    the fans seemed to me to be normal, but apparently he was suprised that they come on full blast when the light is on.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    P1483 is also connected to fan current draw.
    Siezed fan motor??
    Sutton Coldfield
    Right, took it to a garage (recommended by colleagues, and non Vauxhall!) and they gave me quite a good honest view
    They said that the fans is working in an off or on mode, rather than the usual stepped speed. as the fan is working, it is no danger whatsoever to the engine or the drive, just would be noisy when i stopped at lights etc.
    they tracked the fault down to a small ECU chip in the fan, which can only be replaced by Vauxhall dealer, which means £££££! so i'm going to ignore it, and just have the light on my dash. kind of got used to it now...
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Scrap yard for this item??
    Sutton Coldfield
    apparently when you put it in, it has to be coded to the car's VIN, thats why the local garage couldn't do it.
    gone are the days of Haynes manual DIY at home...
    Regular Member lesbo's Avatar
    Feb 2007
    ANGLESEY
    Wonder if this is the same problem I've had with my 2.0T. Heavy ish load in the boot, drove for about 70 / 80 miles. Stopped for about 1hr. On starting engine the "engine" shaped light, believe it's the emissions light, came on. After a few attempts I managed to clear it. Same happened on return journey. Now with the car empty I have no problem. Haven't checked whether fan is coming on or not though or is this a totally different problem???
  1. Fault code P1125 + Emissions light
    By Aaron1976 in forum Engine & Drivetrain
    Last Post: 7th January 2013, 16:52
  2. EML light when first starting, no fault code recorded???
    By portreathbeach in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2012, 21:58
  3. Fault Code Pic - Anyone wanna shed some light
    By Leemarksmith in forum Engine & Drivetrain
    Last Post: 17th March 2012, 08:11
  4. Emissions Light - Fault Code Help!!!
    By Stu_2010 in forum Engine & Drivetrain
    Last Post: 4th January 2010, 23:48
  5. Spanner Light with P1191 fault code?
    By simp_2.2sri in forum Troubleshooting
    Last Post: 16th October 2008, 20:14
