Results 1 to 10 of 15
Thread: Is it possible to....?
    Regular Member bizerk's Avatar
    EDINBURGH
    Default Is it possible to....?
    Hi all, This is my fisrt post..
    Ive just bought a 2003 vectra c 1.8 ls, the only thing wrong with it is that the driver side window / mirror switch control is missing.
    Couple of questions -
    Is it possible to close the driver side window with out the switch? as it is open about 1/2 an inch.
    and
    Wheres the cheapest place to buy a replacement switch from?
    Many thanks
    Nice site!!
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    probaly ebay.. theres 1 one at the moment.
    Regular Member david.aka.judas's Avatar
    Suffolk
    Quote Originally Posted by bizerk View Post
    and
    Many thanks
    Nice site!!
    try this:
    unlock the doors, then double lock and hold down the lock button.
    the windows should come up.
    or hold open and they should come down.
    see if that works.
    Regular Member mitchell's Avatar
    northumberland
    put ya key into drivers door lock, lock then dead lock and keep the key in the locked position and the windows should fully close. If not then the chances are theres something blocking it on the inside, possibly a cable if you've fitted after market speakers or something........just pop off the door card and have a look. HTH
    EDINBURGH
    Many thanks guys!!!!
    I was able to use the key to close the windows, was a little worried that the car was going to get soaked in the rain before I was able to buy a door switch.
    Cheers again
    Dave
    11 Post(s)
    Quote Originally Posted by mitchell View Post
    I didn't think that worked with Vectra-Cs? Pretty sure it didn't on my previous 53 reg, and definately doesn't work on my current 06 reg.
    Works on mine (03) and covered in PDF manuals I have up to 04 (i.e. I don't have the 05 and 06 versions). In the 07 PDF manual it doesn't mention it, so I can only assume it was dropped on the facelift?
    northumberland
    typical duncan yet another good little trick thing that they dropped.......my siggy works as well 54 plate. get a decent car and the possabilities are endless
    Yep, they dropped quite a few little niceties on the facelift, although I think it also gained some as some sort of balance.
    11 Post(s)
    Can't find mention of key in door lock operating windows in my Aug 2003 pdf manual. Only reference is to hold down the remote fob buttons to do the opening / closing - which worked on my 53 reg and 06 reg.
