Thread: Turbo boost valve
    Regular Member dan1983's Avatar
    North London
    Default Turbo boost valve
    Hi can someone tell me if there is any point in fiiting one of these, can i increase the boost without damaging the engine/turbo? what does the normal turbo run at?
    Are you meaning a dump valve?
    Regular Member joules2.0t's Avatar
    surrey
    Trim : SRI
    Year : 53
    If you mean a bleed valve, then I don't think it will work with the z20NET Tronic 8...
    May 2006
    n.ireland
    huds has something like this? could be wrong.
    Regular Member hudz's Avatar
    northern ireland
    Yes mate,i,ve a bleed valve fitted,you'll only get about 2-3psi max out of it before the ecu reads an overboost and puts it into "limp" mode!
    surrey
    Trim : SRI
    Year : 53
    LOL - a bleed value can be a dangerous mod! Bleed value and blown turbo normally go hand in hand or bleeding valve!!
    member of the smoke patrol 230bhp+
    what are you trying to do
    are you looking to make your car faster or more boost
  1. Boost valve help!
    By Basher1 in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2012, 13:32
  2. boost valve
    By stanlee in forum Diesel Engine related
    Last Post: 15th February 2011, 18:44
  3. Turbo Boost Control Valve?
    By stupottyuk in forum Engine & Drivetrain
    Last Post: 20th July 2010, 12:59
  4. What is a boost pressure valve
    By darveccy_c in forum Introduce yourself.
    Last Post: 1st January 2010, 23:52
  5. Fse Boost Valve ?
    By Mads in forum Petrol Engine related
    Last Post: 19th September 2008, 20:43
turbo booster valve vectra c
