Results 1 to 7 of 7
Thread: Electrical Power Dip
    Feb 2009
    midlands
    Default Electrical Power Dip
    Can anyone identify with this problem?.....
    At low revs when manouvering in car parks etc, the heater fan, lights etc 'dip' as if there is insufficient electrical supply. A quick increase in revs retrieves the situation.
    Is this a known problem on a 1.8 Petrol.
    Is it easy to fix
    Thanks in anticipation.
    Telford, Shropshire
    Trim : Elegance
    Engine : 2.2 Direct
    Year : 2003
    It's a known problem as i've seen a few people on here mention and i have the exact same issue in my 1.8 Club.
    As to if there's a fix, I expect someone knowledgable will be along shortly
    Oxfordshire
    13 Post(s)
    Vehicle : Vauxhall Astra-J
    Engine : 2.0 CDTi
    Year : 2013
    It'll be the electric PAS pump. It uses a lot of power and slight dimming of headlights, etc is normal when the car is only ticking over.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    its normal m8
    Aug 2006
    Is a very naughty boy
    Perfectly normal, the pas pump is electrical and it draws a large current. You will also notice the lights "dip" when the abs or tc cuts in on these slippery roads!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    My 1.8 does it too. Power consumption from PAS is the answer (as mentioned above). I guess the only way to stop it is to fit a larger capacity alternator and bigger battery - but i'm still not convinced you would completely eliminate it even then.
    May 2008
    Dunfermline, Fife
    same here, Power Steering related.
    Kev
  1. Electrical project - Power feed
    By MrDerv in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2012, 00:34
  2. Electrical help please
    By bensterzback in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2011, 15:29
  3. Power Steering, Electrical or Belt Driven?
    By Waterboy in forum Engine & Drivetrain
    Last Post: 5th February 2009, 23:41
  4. electrical
    By lee324uk in forum Engine & Drivetrain
    Last Post: 1st December 2008, 09:34
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
