Results 1 to 10 of 18
Thread: 1.9 CDTi intermittent stalling
    Thatcham, Berkshire
    confused 1.9 CDTi intermittent stalling
    This is my first post - so hi everyone!
    I've got an 05 plate 1.9 CDTi 150, and the flipping thing has an intermittent stalling issue. It's been regularly serviced and has 41K on the clock. Currently used just on short journeys by the wife around town.
    History: It first happened when it was still under warranty about a year ago, and under warranty we had a new inlet manifold gasket fitted which cured the problem for about 3 months.
    Numerous visits back to the garage from then until 6 weeks ago when they said they had finally found the problem - diesel filters...weird thing is they were changed during the service in December, but this seemed to have worked until 2 weeks ago when it started to do it again!
    It normally happens at low revs, like roundabouts and traffic lights. You can't restart with the key straight away, you have to wait between 30 and 60 seconds before it will start again. But, if you're quick you can jump start it before you stop - and this works.
    Taken it back to the garage a few times over the last 2 weeks and they can't find a problem with it (although the idle is rough to me it's not to them). They say that there's a common fault which causes this issue, but won't do anything about it until they either get it to stall or something comes up on the computer - surely if it's a common fault they'll just fix it?
    My main worry is that the car is no longer under warranty...any ideas gratefully received as I'm losing confidence in my local dealer.
    Lancashire
    Thatcham, Berkshire
    No - however when the car is cold it's really lumpy...as soon as it's warm the idle is much smoother.
    Thatcham, Berkshire
    Anyone got any ideas about this - happened a few times yesterday...and now it's being fine!
    It seems to be linked to damp / wet weather??!!
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    I had this problem on mine.. When i decelerated and coming to a standstill the engine would cut out.. Wouldnt restart straight away either... sometimes had to leave it for a cpl of minutes... Did it on and off over the course of a few months and then seemed to disappeared. I was gonna keep an eye on it, but had the inlet manifold changed due to the swirl valve rod. Been serviced since the cutting out issue and touch wood, never happened again.. So dunno what caused it really.
    Thatcham, Berkshire
    Sounds like the same problem...I'm sure the manifold was changed under warranty last December as part of the service / snag list I had built up.
    Is there anyway to do a manual check on the swirl valve rod?
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    dont think that was the cause of the problem but swirl valve issues are known about by Vx, plenty of threads on here too.. Pop the engine cover off you'll see the swirl valve rod its a metal bar which goes across the 4 cylinders, check to see if its still on and if theres any build up of gunk around the 4 valves it sits on... If its faulty it'll either be off altogether or very loose or jammed. You can check this by getting someone to start the engine and see if it moves when started.
    Regular Member Karl's Avatar
    Sunderland
    sounds daft but you say the car is only used fro short journeys? couple of reaons it could be doing it.
    I wonder if the DPF has had a chance to regen lately? (drive for over 30 mins on motorway to clear it out)
    How long does a tank of fuel lie in the tank? could be a crappy/old batch of fuel (I have had this)
    I would try a fresh tank of V power diesel and a good blast down the motorway. With you saying it went when the filters were cleaned then returned it kinda suggests there could be a fueling issue.
    I would also check the fuel cap, if the above fail to fix it then remove the fuel cap and retest, might be a vacuum issue.
    Thatcham, Berkshire
    What's a DPF?
    Where's the vacuum pipe for the fuel tank? I do remember that when I last filled it (a looong time ago) there was a sudden rush of air!
    Regular Member VECTRA_C_VIPSTYLE's Avatar
    CHESTER
    ok the vectra b I had this problem it was the air control valve try that ??
  1. Intermittent starting on my 2004 1.9 CDTI 150
    By burgher in forum Vectra C / Signum Troubleshooting
    Last Post: 30th November 2012, 12:50
  2. 1.9 CDTI 150 Intermittent Stalling When Running
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 11th August 2012, 22:03
  3. 2.0Dti (Y20DTH) almost stalling - intermittent
    By MatB in forum Engine & Drivetrain
    Last Post: 7th June 2011, 17:45
  4. CDTi 150 intermittent running problems
    By JonSRi150 in forum Engine & Drivetrain
    Last Post: 20th December 2010, 14:13
  5. 1.9 CDTI stalling
    By OilBurner in forum Engine & Drivetrain
    Last Post: 19th January 2007, 14:09
