Thread: Any Difference Bilstein B4 from hatch to Estate ?
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Default Any Difference Bilstein B4 from hatch to Estate ?
    Having just fitted a Second hand set of Bilstein B4's from a Hatchback to my Estate , I have now decided to ask the above question
    Only reason i ask is that i now feel that the New B4's (They have covered a couple of thousand Miles) Feel softer on the rear !!
    Trouble is to compare like for like again , I would have to remove one off the car..
    I suppose what im asking is ?
    Is the standard 1.9 Cdti Estate suspension any more Damped than a Standard suspension on a Hatchback ?
    Dean
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    The Estates are heavier, the springs are different for sure to cope with this so would have thought that the shocks would be for an Estate would be firmer also. Can you not go on to there site or LMF and compare part numbers?
    Nov 2007
    Staffordshire
    Just Checked on LMF & they state the same as below
    Bilstein B4 Rear Shock Absorbers - Vectra C and Signum
    Suitable for the Signum and Vectra C Hatchback, Saloon and Estate without electronic suspension control. These shock absorbers are supplied individually. If you require a pair, please order two.
    The springs went on the Axle weights again as per Lmf ..
    I think it may just be me !! You know how your mind plays silly tricks on you !!, If it is dry tomorrow night , I think i'll whip a rear shocker off & test again side by side with an independant adjudicator
    Dean
    Vehicle : SRi
    Mileage : 137000
    Your right mate, just checked LMF and Demon Tweaks and there the same part number.
    Nov 2007
    Staffordshire
    Cheers rushy
    Dean
  1. Replies: 21
    Last Post: 4th November 2012, 22:31
  2. Bilstein B4 on Sri 3.0 Cdti Estate?
    By stoph in forum Suspension, Wheels & Brakes
    Last Post: 1st March 2012, 10:39
  3. Bilstein B6 ( Estate )
    By Sebastian in forum Parts for sale
    Last Post: 10th December 2009, 20:18
  4. Estate sri XP v Hatch sri XP
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2007, 17:29
