Results 1 to 10 of 23
Thread: Replacing a steering wheel
    Regular Member Karl's Avatar
    Sunderland
    confused Replacing a steering wheel
    Sorry if this has been covered but I have tried to search:
    I have just got a new SRi steering wheel to replace the crappy Life one I have, I know how to change the steering wheel but am a bit hesitant about the air bag....
    Is there a specific process (I assume battery off is a must)
    Just thought I would check before I end up with a mini explosion in the car and a hefty bill.
    Cheers in advance
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    yes m8, disconnect the batt and on the side of the steering wheel /airbag you will see 2 small holes . so with a flat screw driver point it towards the middle and push the handel inwards so you release the clip inside and then do the same with the other side. once that has been done unclip the airbag wires. then with a torx socket undo the the bolt which will release the steering wheel
    Sunderland
    cheers mate, off to do it after some food. Looks and feels soooo much better than the standard crap that is fitted.
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by glynn View Post
    yes m8, disconnect the batt....
    ..and leave for about 20 minutes before doing anything else to allow the air bag to discharge I think Glynn meant to say.
    yes d i forgot that bit
    Sunderland
    these two holes? On the back you say? Found them, but nothing moving? Help?
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    quarter turn of the steering wheel will reveal the holes. Flat blade screwdriver and wiggle. You are opening up two roller bars. Hold the airbag with other hand and pull towards you. Alternate the holes and it will come off. T50 TORX bit for the bolt.
    Regular Member Matt's Avatar
    in a 3 bedroom house
    we did ours yesterday, and it took a bit to get the airbag out the first time but it was a 2 min job the second time
    Sunderland
    think i might have got it....
    Sunderland
    confused
    Quote Originally Posted by John35 View Post
    argh, if I had known that bit I wouldn't have started, assumed my largest (t40) bit would be ok, obviously not......
    Looks like a trip to the tool shop in the morning and start again tomorrow night.
    Can I confirm that I jsut pull the end of the two (airbag) wires (where it goes into one) out?
    Cheers for the help thus far, been invaluable. even been checking from phone while in car to make sure no new posts were up so I didn't make any mistakes! lol
  1. For Sale: Sri facelift steering wheel c/w steering wheel controls
    By andy.l in forum Parts for sale
    Last Post: 3rd February 2013, 16:08
  2. Replacing steering wheel controls
    By dunkymunky in forum Electrical & ICE (including SatNav)
    Last Post: 15th June 2012, 18:19
  3. Replies: 6
    Last Post: 13th March 2011, 10:47
  4. need help vectra c 1.8 replacing steering transponder
    By morgan1664 in forum South Wales (RO - Vacant)
    Last Post: 1st February 2011, 18:24
  5. Steering light on after replacing inner joints
    By peterman63 in forum Suspension, Wheels & Brakes
    Last Post: 17th May 2010, 18:38
