Thread: painting alloy aerial
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    Default painting alloy aerial
    i recently purchased an aerial off ed taylor and im now thinking of spraying it black to match the car!! could someone tell me what i need to do it? i already have the black spray but does i need priming or anything? tia
    Sunny Dartmoor
    I would prime it first,and then a few light coats of black then a couple coats of laquer,good luck m8......
    Regular Member Baz07's Avatar
    Lancashire
    Just give it rub down with 1200 grade to give the paint something to stick to...
    [Ex]Admin Duncan's Avatar
    I simply rubbed mine down with some 1200/wet and dry and then a couple of coats of paint and lacquer. I didn't use primer as with it being alloy coloured it was grey anyway, and it turned out just fine.
    Feb 2007
    Quote Originally Posted by glenboy View Post
    cheers mate ill have a go when the weather is better
    Quote Originally Posted by Baz07 View Post
    cheers baz that was my next question
    Feb 2007
    cheers duncan thanks for the thread
    Feb 2007
    how long should i leave it to dry in between each coat? and does it need rubbing down again before the next coat?
    Depends on how warm it is really. The aerosols paint (Vx ones) dry fairly quickly. I think I just put it in the airing cupboard for about half an hour each time.
    I didn't rub down between coats and the finish was nice and smooth. The important thing is to make sure you use thin even coats.
  1. House Painting & Decorating - Corner/Edge Painting advice
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 14th January 2011, 17:45
  2. Alloy wheel painting
    By Danialj32 in forum Styling
    Last Post: 3rd November 2009, 13:57
  3. Quick wash and fitted new alloy aerial
    By lofty in forum Quick Photo Album
    Last Post: 21st May 2008, 10:23
