Thread: Roof Rack/Bars
    Default Roof Rack/Bars
    Does anybody know who makes the Vx roof carrier system?
    I need to get a set of roof bars for my Vectra estate (which doesn't have side rails). The set on the Vx site look similar to a Thule set I've seen but I can't see whether they can be locked like the Thule ones can.
    Regular Member greeningr's Avatar
    Jan 2006
    Oswestry
    i know that thule make the roof racks for Ford, Toyota and Mazda, so I guess that they will probably make the VX one also
    Thule do make them for the vectra, according to halfords but are special order only. Top end of the price range, ie virtually same price as Vauxhall ones, but look very good quality. And yes, the vauxhall ones have a very neat securing system, with levers that lock the feet in place. There is then a lockable cover plate which fits over which tidies it all up.
    Regular Member In a states's Avatar
    Dec 2005
    In an estate car
    I run roof bars all the time...wouldn't stray from Thule at all....lasts ages and looks factory fit....plus spares are easily available.
    Shop of choice www.roofbox.co.uk
    Thanks for the replies. I've hit another couple of snags though.
    Firstly, the width of most standard bars is around 120cm. I need to get slightly longer ones. I can specify them if I go for the Thule aftermarket kit but I think with the Vx kit you get what you're given.
    Secondly, having looked at the mounting points in daylight, it turns out that they're located towards the front of the car and aren't that far apart. Fine for a roofbox but I was wanting to carry a lightweight dinghy (~8ft long).
    Has anybody come across a solution?
    Dec 2005
    In an estate car
    Speak to the guys at roof box very helpful...
    Yet another question ...
    The Thule bars all look like they secure to the roof fixing points via Allen bolts, but looking at the fixing point there's no threaded hole. How does it lock into place?
    Thanks again.
  1. roof bars/rack
    By adibranch in forum Vectra C / Signum Car Chat
    Last Post: 7th June 2009, 11:22
  2. Roof rack/bars wanted.
    By jaxouk in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2009, 19:38
