Thread: Sports suspension??
    Regular Member colalowe's Avatar
    in the North
    Default Sports suspension??
    Is there any way I can tell if I have sports suspension fitted??
    I have the Elite 1.9cdti and it has the 19inch snowflakes on, the ride is quite stiff and you can feel every bump and ripple on the road, the ride height looks normal though??
    Regular Member shan's Avatar
    I would say your motor has the standard elite. The only way I'd tell if it has is to ask, does it fell like it's wollowy on the bends ???
    I put Eibach's on mine and got a 30mm drop and it handles much much better.
    The harsh ride is from the 19" snowflakes.
    in the North
    It doesnt feel wallowy in the bends but I suspect your right and it is just the wheels.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    In your profile pic it looks quite high so i'd say stock Elite.
    If the car came from the factory with the 19" wheels then i am sure they fit the "sports" suspension as standard regardless of the cars original spec But it must have come from the factory with the big wheels !!!!!
    Regular Member VectraV6CDTi's Avatar
    Wilts
    Might be worth asking down the Vx dealers. Give them your chassis no and see if they can trace what spec it had.
    Surrey
    Is there any other way to check factory spec?
    Depending on country of manufacture, it may have a EU Conformity Certificate
    Within this is the suspension specification, and in that column you will be able to tell
    Regular Member rorycarz's Avatar
    Dec 2005
    AYRSHIRE SCOTLAND
    when i got my elite i found it too soft aswell, i fitted stoke sri cdti spring and shocks and found a big difference..i was also runing 19's
  1. For Sale: lowered sports suspension setup
    By andy.l in forum Parts for sale
    Last Post: 30th November 2012, 18:20
  2. Suspension knocking? Will Vec c suspension fit a Siggy?
    By shane5861 in forum Handling & Braking
    Last Post: 6th May 2011, 14:20
  3. WOW SRI Sports suspension
    By Mopar Man in forum Handling & Braking
    Last Post: 26th March 2011, 12:07
  4. Replies: 5
    Last Post: 21st March 2010, 12:34
vectra c sports suspension
