Results 1 to 10 of 22
Thread: Wheel Alignment ???
    North East
    Default Wheel Alignment ???
    One of my big bug bears is when my car steering wheel is not central when driving in a straight line. I have noticed mine isn't true at the moment. Its slightly to the left. I have had the wheel alignment checked and have been told it's fine and correct.
    I keep getting told that its probably just the road camber. Does anyone else have this on their vectra?
    I have had it checked at a local tyre fitting place and not at a vx dealer. Is it worth getting it checked there? Anyone know any good places in the north east nr. m'bro?
    Jul 2006
    I have the same problem on my new signum. I'm hoping new suspension and alignment will sort it out, but I had a corsa years ago that had the exact same problem and it never got any better
    Regular Member Boy Lard's Avatar
    Derby
    When I picked my Vec up earlier in the year it was slightly off to the right so I had the alignment checked (way off apparantly?!) and corrected and now it's slightly off to the left!
    Regular Member shan's Avatar
    I had mine aligned "the wheel" when i fitted 19" snowflakes. Driving in Europe the steering wheel was always to the right. Big Phil told me it was the road camber. When i got off the ferry at Dover the wheel was to the left a touch. I thought smart man is Big Phil.
    Regular Member Stevie-B's Avatar
    Mar 2007
    NI
    Smile
    MPC - Change the car for one of these bad boys....
    Brighton
    Quote Originally Posted by mpc View Post
    Did have this problem, your car needs a "Full Wheel Allignment" there is a post on here somewhere on this issue, it used to drive me nuts, then the tyres wore down - the stearing went straight - change of tyres - problem worse....Absolutely fine now, tyres wear perfectly even cost me £48 but worth every penny to save my sanity and tyres
    North East
    Quote Originally Posted by CorsaVan View Post
    Where did you get the "Full Wheel Alignment" done?
    Michael
    North East
    Can anyone recommend anywhere in the north east (that is good!!) to get a 4 wheel alignment done?
    SCOTLAND
    I've had the same problem after a prang a few weeks ago, car is pulling severely to the left and its definitely not camber. Took it back to the garage who discovered the alignment was out by 7mm- fixed it and gave it back.
    Its back in today cause it started to pull again and is worse than ever. Unfortunately the insurer uses Arnold Clark who's response was - "WELL WE FIXED IT AND ITS NOT OUR PROBLEM"
    Up shot is that it is back with them even though they are not interested so we'll see what happens.
    Incidentally, had this problem when i first got the car and it took them three attempts and a lot of arguing to sort it, should have asked what they did then!
    Anyone got any ideas what it could be?
    www.alignmycar.co.uk for your nearest 'hunter' centre..
  1. 4 wheel alignment
    By tangoman in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2012, 21:42
  2. wheel alignment
    By matt2005 in forum Suspension, Wheels & Brakes
    Last Post: 8th March 2012, 12:32
  3. 4 Wheel Alignment
    By Tam80 in forum Suspension, Wheels & Brakes
    Last Post: 29th January 2011, 20:06
  4. 4 wheel alignment
    By dave_taiho in forum Northern Ireland (RO - Vacant)
    Last Post: 9th March 2010, 16:35
  5. Wheel Alignment?
    By parapaul in forum Suspension, Wheels & Brakes
    Last Post: 23rd November 2008, 23:09
