Thread: will springs fit
    Regular Member mat osborn's Avatar
    Jan 2008
    leicester
    confused will springs fit
    hi all can anyone help just been offered set of sri springs 2 questions will they fit a 55 plate facelift veccy they are from a 06 plate veccy and how much lower will it sit compared to a life model as im under impression its 15mm lower thanks in advance
    if they are off cars with the same engines ( i.e. the same axle weights) then they will be fine.. physically, all vectra/signum springs fit all cars, but it's the axle weights that determine if they will sit and ride okay..
    if they are off a car with an identical or similar axle weight, then they will drop yours by 15mm and stiffen the ride up slightly...
    Jan 2008
    leicester
    where abouts do you find axle weights would the be on info plate
    yep, that would be on the black plate on the drivers door pillar.... they both must be close (within 10kgs) for it to get yours lowered that 15mm
    Jan 2008
    leicester
    thats great thanks for your help ill go and check now
  1. replacing standard springs with Sri springs
    By mon in forum Handling & Braking
    Last Post: 31st December 2012, 22:03
  2. springs? coilovers? shocks/springs?
    By Dan. in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2011, 19:01
  3. Replies: 5
    Last Post: 21st July 2010, 16:14
  4. vxr springs
    By supersione in forum Handling & Braking
    Last Post: 18th July 2010, 16:21
  5. 2.0T SRI Springs
    By Baz07 in forum Parts for sale
    Last Post: 9th July 2008, 13:28
