Thread: Final Prep
    Default Final Prep
    After spraying my latest additions, the clear coat has gone a little dull, it doesn't have a nice glossy finish. ANy ideas why? or can I now polish it up when its nice and hard - oooo errrr
    Regular Member Craig1985's Avatar
    harwich essex
    it goes dull because it was too cold when painted n left to dry. it needs to be around 35 degress i belive? ( this is what ive always been led to belive?)
    harwich essex
    was the clear coat mixed/shaken well?
    Yes, well mixed. Its not cloudy, just not glossy
    Regular Member Baz07's Avatar
    Lancashire
    I am led to believe that after the clearcoat has set, you use 1500 wet&dry then a rubbing compound such as 3g.
    Then polish to a shine.
    I was told that the clearcoat has a top layer that has to be finished as above.
    HTH
    harwich essex
    Quote Originally Posted by Baz07 View Post
    HTH
    try this as it also helps loose "orange peel effect" just leave it a day or two to completly dry tho
    Hmmm, i have some 1200 grit, is that too much? also have the rubbing compound.
    harwich essex
    abit rough i would say? 1500-2000 grit much safer.
    i used 2000 n rub it on its self then use it.
    (use in touch ups on chips n small scratches)
    Maybe i'll get some 2000-3000 first then. In the mean time, cutting compond and elbow grease
  1. Pad Prep
    By Ben_ in forum Detailing and Car Care Discussion
    Last Post: 13th June 2011, 11:45
  2. A Little bit of Prep Work!
    By Maverick in forum Non Vectra C/Signum Album
    Last Post: 27th May 2011, 13:08
  3. Prep work
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2010, 20:09
  4. A few prep and spraying questions
    By swainey in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2009, 21:47
  5. Le Mans prep almost complete.
    By Brocks in forum General Chat
    Last Post: 9th June 2008, 10:37
