Thread: High Level Brake light
    manchester
    Default High Level Brake light
    I stripped down the tailgate as I wanted to replace the rear level brake light on my 2.0dti hatch vectra c and to my suprise there is no access to the light unit itself. There is a metal palte welded over it, cant even get to the wiring. The haynes manual states that I should clip it out from the inside but this is impossible. Any ideas how to remove it??
    yep, gently prise it out from the outside of the bootlid.. it's on clips..
    manchester
    Thanks for that Mark, any idea if I would have to replace the whole unit, or is it pos to replace the individual l.e.d's.
    May 2008
    Tyneside
    Comes as a complete unit from dealers, just fitted a clear one £40. The vauxhall technical information sheet for this procedure says you have to drill 3 holes in the back of the surround to access the bolts (4mm allan key). The positions are shown with a dimple on the panel. Don't forget to paint the drilled edges when finished.
  1. high level brake light
    By markj23 in forum Electrical & ICE (including SatNav)
    Last Post: 12th July 2012, 00:32
  2. High level brake light
    By gtr1000 in forum Electrical & ICE (including SatNav)
    Last Post: 9th December 2011, 09:03
  3. high level brake light on hatchback.
    By mick 1986 in forum Styling
    Last Post: 22nd July 2009, 17:13
vectra c high level brake light removal
vectra c high level brake light on
