Results 1 to 10 of 15
Thread: Lumpy tyres
    Oct 2007
    Gloucester
    Default Lumpy tyres
    Just got back from having to have 4 new tyres fitted and have a question about the rear suspension.
    My front tyres were predictably worn across the whole tread. The rears however were completely strange.
    On the inside shoulder, the tread was distinctly lumpy as you looked across the tread . I've never seen anything like this and was wondering if anyone could shed any light on the problem. Is tracking just something for the front wheels or can the rears be adjusted too?
    it's to do with the setup on the rears.. before you do the same to your new tyres you need to get the car wheel aligned..for both camber and toe..
    one of these centres can do it correctly for you..
    www.alignmycar.co.uk
    Could this also be down to worn rear shocks?
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Insignia elite tourer vxline biturbo
    Trim : Elite vxline
    Engine : 2.0 biturbo
    Mileage : 80000
    bouncing up and down kerbs when coming of drives .. had a similar prob with my vectra b... thats what the tyre place told me
    Oct 2007
    Gloucester
    So will a full alignment be worth the extra money over a standard tracking check? It says that the cost of an alignment is about the cost of a tyre (£80 ish I guess) but a tracking will be considerably cheaper.
    the full alignment is what you need, and yes it is worth it.. cures all the cars that i see with the problem.. it's dearer than a tracking session, but it does take longer to do, and adjusting the camber normally moves the toe as well, so it is a bit of a fiddle
    Quote Originally Posted by bigknill View Post
    This is usually a sign that the rear tyres are losing contact with the road, suggesting either worn shock absorber, linkages, or bushes
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    Post
    & on my last car, scalloping of the rear tyres sounded like a rear wheel bearing on it's way out
    ps: easy way to check is run your hand over the tyres & it's rough one way & smoother the other way
    lol after getting new rear tyres & a full alignment all was fine
    Or , on the vectra C, excess camber caused by poor setup on the rears.. seen it many many times..
    Oct 2007
    Gloucester
    Well, following the typically excellent advice on here, I've booked the car in to have a 4 wheel alignment on Thursday. Not cheap, but if it saves me the cost of two new tyres before they're dead.
    Cheers for the advice chaps!
  1. running lumpy
    By bert01909 in forum Engine & Drivetrain
    Last Post: 9th January 2012, 15:10
  2. lumpy idol
    By Ray_Ray280 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th November 2011, 18:10
  3. Lumpy Engine
    By thefibreguy in forum Engine & Drivetrain
    Last Post: 29th July 2011, 10:57
  4. lumpy idle
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2008, 20:39
  5. Bit lumpy?
    By speedo in forum Engine & Drivetrain
    Last Post: 25th November 2007, 19:09
