Thread: New key, chip and ecu
    surrey
    Default New key, chip and ecu
    Hello all,
    I have a T reg 2.0 16v vectra which my daughter lost the key for . I have been told that if I buy a new key and chip from vauxhall it needs recoding at the dealer etc. I have also been told that if I buy a used key and lockset, chip, chip that goes under the steering wheel and ecu, this will do the job without recoding. If the used kit is working correctly will this do the job?
    thanks in advance.
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    basically yes. the bit around the steering wheel is what recognises the transponder chip in the key.
    Regular Member BIG NEIL's Avatar
    Oct 2007
    Back in Belfast!!!!
    As long as you have your key security code that should be in your hand book you should be able to get a new key ok.
    i just had my spare key re-programmed today needed the security code to do this.VX charge £35 +vat for this unless you know someone
    Regular Member fenderguitar's Avatar
    Portadown Co. Armagh N. Ireland
    Quote Originally Posted by BIG NEIL View Post
    thats not too bad,I know guys that got dearer quotes
    Oct 2007
    Back in Belfast!!!!
    that was ballyrobert in bangor jim
  1. Key chip help
    By chay6684 in forum Electrical & ICE (including SatNav)
    Last Post: 7th February 2013, 19:28
  2. Chip
    By ianuk in forum Diesel Engine related
    Last Post: 14th November 2009, 16:43
  3. Re-map or chip?
    By anthonychall in forum Diesel Engine related
    Last Post: 4th April 2009, 10:12
  4. Chip...
    By acb in forum Diesel Engine related
    Last Post: 1st September 2008, 09:04
  5. Can I Use Chip
    By 21_03_sxi in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2007, 13:28
