Results 1 to 10 of 20
Thread: true or not
    Regular Member willoftoon's Avatar
    FOREST HALL NEWCASTLE ,,,,,OR DECKHAM ,, ON SUNDAYS .. DINNER TIME MAMMY,S
    Default true or not
    as u know i have a diesel sri ok i know about light ,, glow plugs b4 i start it .but some 1 told me i have to sit in car for seconds when i pull in me drive b4 i turn engine off wtf is this true coz i dont i pulllin turn off get out and bobs ur uncle
    Regular Member chrisschild's Avatar
    May 2006
    Wiltshire
    Vehicle : Vectra Hatchback
    Engine : 2.2 DTi
    I tend to let mine sit & Idle for 30 secs or so just to let the engine settle. Same when starting, I dont pull away till engines been running for a min or so. But thats just me...lol
    Regular Member chinky's Avatar
    midlands
    ive driven diesels for years for work and its stop start short trips and ive never let it settle and often drive away asap and never had an issue my last car a focus had 110.000 miles and only let me down once still original clutch and exhust and glow plugs
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    i let mine settle for a few seconds before turning off but im sure there was a thread earlier saying it was not good to let your engine idle from cold
    same with me work van stop start all day just a lad says got to let it settle or sumit due to oil in parts ,, or sumit says fit a turbo timer eh fitting nowt but whats a turbo timer
    norn iron
    i think it has something to do with letting the turbo cooling down. im sure someone will clarify soon
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    its to do with the turbo mainly, you need to let the turbo stop spinning. if you turn the engine off without settling the turbo then it will continue spinning without oil. can be a problem later in life, it also relates to other moving parts in the car but the turbo is the main concern. Starting off you just need to let the engine settle from turning on, let the revs drop back to idle then your fine
    Regular Member Matty H's Avatar
    Bristol
    Quote Originally Posted by chrisschild View Post
    I'm glad I don't live next door to you if you do that every morning in a diesel
    Tyneside
    Regards to the turbo it will only have effects if you've been driving it hard and then you switch it off straight away as this is how to kill a turbo quickly, but if it's just easy driving there wont be any major effects. Personally I let it run for about 30 secs if I'm driving normally for reassurance and if I'm driving it spiritidly(is that even a word) I'll let it spool down while driving to let it all settle then let it idle for a minute or two
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Only a problem with engines fitted with a turbo. When stating do not over rev the engine, but no need to sit and let it idle.
    When stopping it is recommended you let the turbo spool down (stop spinning) before switching the engine off, this is only usually necessary when the car has beeen driven hard then stopped quickly. Normal sane driving as you arrive home it should not be required.
    3.2 v6 Signum and loving it
  1. true or what ?
    By hoochydady in forum The 'Off Topic' room
    Last Post: 24th November 2010, 22:19
  2. Is it true
    By vecgsiboy in forum Electrical & ICE (including SatNav)
    Last Post: 26th January 2010, 00:09
  3. True or Not?
    By kaster in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2009, 21:47
  4. Is it True ?????
    By redbullkid in forum Comedy & Humour
    Last Post: 23rd January 2009, 16:38
  5. True or not
    By signumT in forum Tuning
    Last Post: 10th July 2006, 21:20
