Thread: Xeon Headlights
    Regular Member Mark2.2's Avatar
    Feb 2006
    North East Uk
    Default Xeon Headlights
    Does the Vectra C come with these as standard now? It looked like my old lights had xeon ones in them, when I removed the damaged ones. When I buy the smoked facelift ones will those be xeon?
    Surrey
    Xenon no, not as standard.
    Regular Member chrisschild's Avatar
    May 2006
    Wiltshire
    Vehicle : Vectra Hatchback
    Engine : 2.2 DTi
    Xenons only come on the Vectra/Signum's with AFL headlights. Or Elite, GSi & VXR's.....I think...though someone else will correct me.
    Feb 2006
    North East Uk
    How can you tell if you had Xeon ones fitted?
    Feb 2006
    North East Uk
    Ah, it's just they look different from the old kind of lights I am used to on my old Vectra, Astras
    This is my old Headlight:
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    Quote Originally Posted by Mark2.2 View Post
    If they have Xenons then the car will have headlamp washers as well.
    yeah, all Vectra C's and Signums come with Elipsoidal headlights (the dome shaped ones...) which look like the old Vectra B Xenon headlights:
    Pre-facelight Vectra C's with Xenons are either GSI's, which look exactly the same as normal ones, or have Adaptive Forward Lighting, as shown here:
    Facelift C's have xenons as standard only on the VXR's, and again they look like normal ones, unless they are the full AFL type, which look like this:
    So, in a nutshell, unless you buy a VXR or GSi, it's down to pot luck as to whether AFL was specified when the car was ordered. THis makes it very hard to come across, unlike the old Vectra B range, which had it as standard on the top CDX trim level...
    Which is rubbish, because they're excellent...
    Also, and easy way to check isto see if you have headlight washers or not. If you don't, then you don't have Xenons. They're a legal requierment to have them along with a self-levelling system...
    Feb 2006
    North East Uk
    Thats helped me a bit. Cheers for that info
    Also the easiest way to tell is if you have a level adjuster knob on the switch you will NOT have xenons as they are self levelling !!!!!
    May 2006
    Wiltshire
    Engine : 2.2 DTi
    I think what confused you mark2.2, was where ALL the vectra c's/signums have the dome shaped lenses.....which as said were only used on the Vectra B's with Xenons.
  1. Headlights
    By Tam80 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2011, 16:11
  2. GAS DISCHARGE Xeon lights
    By m3ath3ad in forum Electrical & ICE (including SatNav)
    Last Post: 10th March 2009, 23:18
  3. Bl**dy Headlights.....
    By Signum_CDTI in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2008, 00:01
  4. headlights
    By *enery* in forum Styling
    Last Post: 17th March 2008, 21:21
  5. AFL xeon lights?? what are they worth?
    By lee_eardley in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2007, 15:10
