Thread: Signum 3.0 V6 wobble
    tamworth
    Default Signum 3.0 V6 wobble
    Hi Guys, Just having a bit of a nightmare just bought the signum (Fantastic) but it has a wobble when i accelerate over 50. The garage has had it for five weeks and have changed the drive shafts and stability arms. Now they have said it is something to do with the engine management system is that right? they are having the software updated as well. Has anyone else had this problem?
    Regular Member BIG NEIL's Avatar
    Oct 2007
    Back in Belfast!!!!
    when you say wobble ,in what way?
    does the steering wobble or is it like an engine jutter when you are excelerating from low revs
    tamworth
    It wobbles on the steering wheel and through the car. I have had the wheels balanced 4 times and tracking done. But when cruising there isn't a wobble, its starts as soon as i accelerate. Have you had the same problem?
    Oct 2007
    Back in Belfast!!!!
    No not really wobble through the steering wheel,i was asking because most 3.0 v6's at lower revs accelerating in 4th or 5th there is normally a bit of a jutter,and it just the start of the engine pic up.
    have you tried air filter clear out , i just got a K&N for mine and it is far smoother acceleration maybe worth a go
    Full Member Big Sig's Avatar
    Never had this before. They are very sensitive to getting the wheels balanced spot on, but thats about it. It sounds like the garage don't know either and are just replacing parts hoping it solves it - hence the problem still being there. I hope they are not charging you for this and are talking compensation for ruining your new car experiance.
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Might be an outside chance it could be the engine mountings, as you accelerate thats when they have the most strain on them.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Are you acelerating hard?
    Could it be traction control related?
    I would think if it was engine mountings the judder/wobble would be constant. Can you physically shake the engine to see if it has any movement in it, I know that will not be easy.
    Do your front tyres have equal wear on them, as if one is nearly new and one is nearly on the limit they will have different grip which will mean the traction control will have to work harder to keep both turning at the same speed.
    Just some thoughts hope they help.
    3.2 v6 Signum and loving it
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Try swapping the wheels front to rear,could be an out of shape tyre.
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Worn Steering Rack Ends, I had this on another vehicle i owned & no amount of balancing would cure it until i replaced them ..
    Dean
    Regular Member VectraV6CDTi's Avatar
    Wilts
    Quote Originally Posted by tyreman View Post
    Or better still, see if someone off here lives close and can lend you their wheels for an hour. Swap all wheels over and test it. This will at least eliminate anything to do with wheels and tyres.
    Or maybe get the Vx dealer to do this for you. They must have some similar wheels they could borrow off a car.
  1. Wobble!
    By GoldenWonder in forum Suspension, Wheels & Brakes
    Last Post: 5th July 2011, 12:20
  2. bum wobble
    By Al 22 dti in forum Suspension, Wheels & Brakes
    Last Post: 18th May 2011, 12:47
  3. Wobble between 20 and 30 mph
    By Tigger in forum Suspension, Wheels & Brakes
    Last Post: 12th January 2011, 00:28
  4. Wheel wobble
    By signumboy in forum Handling & Braking
    Last Post: 2nd November 2010, 16:25
  5. Signum front wobble
    By Agoogy in forum Suspension, Wheels & Brakes
    Last Post: 20th November 2007, 18:12
