Thread: anybody with a Vec / Signum Design
    Regular Member MrLOL's Avatar
    Wakefield, West Yorks
    Default anybody with a Vec / Signum Design
    If so can you explain how you work the heating controls. These are listed as having "automatic air conditionning" different to having just "air conditionning" on lower models
    But its not the electronic climate control that the elite has
    can somebody explain the difference between aircon and automatic aircon plz ?
    many thanks
    Aircon is basically an on/off button with a temp dial. Auto A/C is where you set the temp - ie to 18 degrees. The auto was an option but standard in all the V6 Models. The Elite was standard with the auto A/C
    so if you set the temp with auto A/C
    how does this differ from the ECC ? i always thought climate control was that you set a temp, instead of manually controlling fan speed.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Auto AC only controls the temperature; ECC has auto control of the fan speed and ventilation openings, two zones and more sensors (and air quality sensor and cooled handglove compartiment)
    Quote Originally Posted by sig63 View Post
    Elite had Climate Control. There are three different options that you'll find on a car according to spec normal AC (simply chucks out the cooled/warmed air at a constant rate depending on the temp dial setting), auto AC (as explained above) and Climate Control (as above)
    Regular Member luckyluke's Avatar
    May 2008
    S'port and L'pool
    Auto AC only controls the temperature; ECC has auto control of the fan speed...
    Automatic has it as well. And what I find annoying is if it's too hot outside you have to switch on air conditioning by yourself - in my previous car when AUTO was on it was freezing automatically.
    ... and ventilation openings, two zones and more sensors (and air quality sensor and cooled handglove compartiment)
    This makes EEC
    You learn something new everyday! I always thought AutoA/C was ECC
    Never knew there were 3 different types
    Quote Originally Posted by luckyluke View Post
    This makes EEC
    so auto ac lets you set the temperature in degrees as opposed to having 1, 2, 3, 4 etc..
    but is otherwise the same as normal ac in that you control fan speed and direction yourself ?
  1. Signum Design 150
    By Calam in forum Introduce yourself.
    Last Post: 18th February 2013, 23:35
  2. Signum 3.2v6 Design
    By kon123 in forum Cars for sale
    Last Post: 10th June 2011, 18:46
  3. Signum 2.0t Design
    By 111 in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 20:18
  4. 2.2 Signum Design
    By Gregg in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2008, 16:38
  5. Signum 04 Design
    By Nealsey in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2006, 14:56
