Thread: Are all vectra c shocks the same?
    Regular Member mic's Avatar
    Jun 2007
    Default Are all vectra c shocks the same?
    I have just had my rear shocks replaced under the network Q warenty and wondered if the shocks are the same for all models. The reason I ask is I have just done a 300 mile trip today on mainly motorways and noticed at high speeds the car seems softer and to wallow more than it did before. The car is an 19cdti sri and I wondered if they have fitted the wrong shocks?
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    i am sure that sri shock's should be slightly shorter and stiffer than other one's, being as they are supposed to be 15mm lower than the other model's that they produce ........
    Midlands Mod Shop - NFFC.
    [Ex]Admin Duncan's Avatar
    On yours, an SRi, it will have different dampers (shorter and stiffer) to the other models. If they've fitted the other type then that would give those symptoms.
    What exactly did they replace? Just the dampers or the springs too?
    EDIT: Do you have an invoice with part numbers?
    Jun 2007
    As far as I know they just replaced the dampers. It was done under warranty so no invoice or paper work. Would I be able to tell which damper they have fitted by looking at it, e.g is a part number visible?
    You may be able to see a part number on them if you're lucky and one of them has the sticker facing outwards. If you can get a number then we can tell you what they fitted.
    Full Member Big Sig's Avatar
    get out there with a torch lol
    Blimey it must get dark early over there !!!!!
    Jun 2007
    Just tried that but my head won't fit between the wheel and the arch. Will get the jack out in the morning and have a proper look and if I find a part number will post up.
    Quote Originally Posted by mic View Post
    Three ways round this...
    First is to ask the dealership to print out the invoice and parts list, however they may decline in which case ask to view it on screen and make a note of the part numbers yourself
    Second, if the above is refused, contact Retailer Warranties directly (see your Network Q policy booklet for the phone number) advise them of the problem, and ask them to supply the part numbers so that you can check if the right parts have been supplied
    Third, visit the parts department and ask if they can check what shock absorbers were ordered and supplied that day, most likely yours will be the only ones!
    Finally, check those part numbers against what should be on your car, from the parts department by checking against your VIN
    For each MY type of the Vectra there are normally four types of shock absorber
    basic - saloon/hatch
    basic - estate
    sports - saloon/hatch
    sports - estate
    Jun 2007
    Ok just had a look at the shock and have got a couple of numbers off them. Does anyone know if one of them is the part number 1st one is 13254789 and the other one is 315000331.
  1. Vectra Shocks with Eibach Pro-Kit
    By Vectra_C_Chris in forum Handling & Braking
    Last Post: 26th October 2010, 14:54
  2. Vectra C - Springs and Shocks (Non-SRI)
    By mishima in forum Parts for sale
    Last Post: 26th August 2010, 09:39
  3. vectra c shocks
    By lloyd.claire2010 in forum Styling
    Last Post: 1st February 2010, 01:12
  4. How to: replace front shocks for Vectra C
    By SeeDeeXeye in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2010, 00:25
  5. Vectra SRi CDTi Rear Shocks
    By richca in forum Suspension, Wheels & Brakes
    Last Post: 10th February 2009, 19:18
vectra c estate wallowing
