Results 1 to 10 of 11
Thread: How can I fit a V-grille on my Opel
    Regular Member jony's Avatar
    VALENCIA (ESPAÑA)
    Default How can I fit a V-grille on my Opel
    Hello everybody,
    I'm from Spain and I've an Opel Vectra post-restyling, I want to remove my Opel grille and fit a Vauxhall, after many problems, I found the way to get one but before asking for that I'd like to know how can I fit it
    The pieces number are:
    OPEL 1322416 - GM 93187812
    Do you think that it's enough with that? What do I have to do to fit it?
    Thanks for your help friends!
    May 2008
    Derbyshire (south)
    Hi mate i swapped mine for just a plain grille,. All you need is a crosshead screwdriver, 10 screws to undo(i think) Then it will drop, away from the bonnet, fitting is reverse of undoing. Took me 5-10 mins to do mine.
    VALENCIA (ESPAÑA)
    Viewing your photo I think you've a pre-restyling... I say 'cos I think it's not the same grille and the way to fit it would be different
    Thanks a lot anyway!
    Jul 2006
    Mexico
    Jony you car is a facelift? if it is changing grilles is much more complicated than on preface lifts.....you have to take down the front bumper to do this I think.
    Feb 2006
    Guttedsville
    On our facelift cars with the larger V grille, when the V is removed, there is the outline of an Opel badge, so it shouldn't be that difficult to swap, but as said before, it's a bumper off job.
    VALENCIA (ESPAÑA)
    Yes, it's a facelift, and I've just request the chrome part, but I'm not sure how does it fit on the black plastic grill...just clipped?
    Then, I've to take down the bumper and after take off the black grille? and ...then?
    Jul 2006
    Mexico
    on preface lift grilles the chrome is glued (plastic welded to the main black grille...I`m almost sure it will be the same....
    VALENCIA (ESPAÑA)
    So maybe if I retire the Opel chrome, the black grille could be damaged?
    And if it's glued, I supose it wouldn't be necessary to take off the bumper...
    Regular Member fenderguitar's Avatar
    Portadown Co. Armagh N. Ireland
    I took mine off my 07 vectra to change the standard grill to honeycombe, the chrome V was just clipped,plenty of clips there was as well.then just reclipped to new grill
    VALENCIA (ESPAÑA)
    So you didn't need to take off the bumper or the black grille?
  1. opel grille
    By signumT in forum Parts for sale
    Last Post: 26th October 2006, 12:55
  2. Opel Vec C grille
    By kitchpoo in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2006, 21:54
