Thread: tech 2
    N Ireland
    Default tech 2
    Has any of you guys got one of these jobbies and if so what years do they work on? i was going to get one but have no idea if it works on the 2008 vectra. so i think it would be easier if i met up with someone that has one and give it a blast, then buy the same unit.
    Jeff
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    what are you looking to do with it? just to be able to get a fault code number listed? There are different models of handheld one which do just fault code numbers from mainly the engine ecu's from about £40-80 ish the next step up in functionality like live data checking, actuator tests etc etc are laptopn based and one version by one manufacturer is about £250-300 and then the top spec software made by vaux-com is the £500 mark.
    Regular Member Durk's Avatar
    Aug 2007
    N. Ireland
    HUDZ off here has two of them. Ask him about one
    Regular Member hudz's Avatar
    northern ireland
    Yes mate,i,ve a couple of these and r first class,i can give u a demo if u want mate!
    N Ireland
    i would like that indeed. just reading through these forums and have came across loads of little things that need to be set via tech 2 and dealers dont really seem to do any of it at all.
    ie the thread about my windows not opening via the keyfob. got a pm from a lad saying he thinks it needs to be done via tech 2
    Regular Member yorkiebar's Avatar
    Jun 2006
    N.IRELAND
    Quote Originally Posted by Durk View Post
    hudz has everything you want and ever need lol
  1. Tech 2 help
    By bish in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2011, 21:35
  2. tech 32 ?
    By les287 in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2011, 21:04
  3. tech 2
    By jamesworts in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2011, 08:17
  4. Tech 2
    By WHOOSH05 in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2009, 16:54
  5. Tech 2
    By cooky516 in forum Electrical & ICE (including SatNav)
    Last Post: 29th April 2008, 11:36
