Results 1 to 10 of 11
Thread: Evaporator drain tube
    N. Ireland
    Default Evaporator drain tube
    Hi all, just looking a bit of advice as to where the evaporator drain tube would be for my aircon. for a while i have been getting the smelly sock stench when my aircon is turned of. I`ve read thought all the forum`s and have tried everything, (comma aircleaner / dettol spray / new pollen filter etc) ...all of which seems to work for a day or two but then back to the way it was. having read on honest john website someone recomended to check to make sure the evaporator drain tube was not blocked as this could be causing the problem. the car they where talking about wasn`t a vectra so i don`t really know where to look tbh. any help is greatly appreciated!!
    [Ex]Admin Duncan's Avatar
    Middle of the car (as in a line in the middle of the bonnet backwards), kinda where the front seats are - maybe a smidge forward of them. Little rubber/plastic tube just sticking down.
    Simple way to check it's not blocked is to park up on some smooth tarmac, ideally with a bit of a slope, turn on the engine and the AC on the coldest setting and after a couple of minutes or so you should see a little stream of water coming out from under the car, like someone weeing themselves! lol
    N. Ireland
    Cool, thanks for this! I hope it is blocked cos i`ve tried everything else. Its really starting to annoy me!
    N. Ireland
    P.s do you know of anything else it could be?
    If you've tried the comma cleaner and a new pollen filter then you've covered the main bases.
    When you changed the pollen filter, did you check to see if it was damp? i.e. have you maybe had a blocked drain hole in the bulkhead area (where the filter is) and water has got past the filter into the vents area?
    N. Ireland
    I didn`t check the filter itself, just binned it. but from what i can remember it seemed dry around where the fan was. there was a LOT of leaves bugs etc around the filter which where dry too. going to get under it in the morning and see if the tube is blocked....fingers crossed!
    p.s just read your post again, come to think of it there was a biggish hose in the bulkhead which seemed to be kinked as it went down, i must check that too..I let you know if i have any joy tomorrow.
    thanks
    Nicking Ya Dinner.
    Get a can of detol antibac spray, it's like £2.99 a tin and large, set the heater controls until you see the plunger behind the pollen filter drop down, start the car and put the a/c on with full blower and spray a good amount in, then, go inside and set the recirculate button to on, then just spray liberally around the car, the fan and recirc will do the rest, best way is to have the window open just enough to spray the stuff in to the car, 5 mins later that smell will be gone, I did it a few times with mine. hth.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Also check that the drainer under the pollen filter is not clogged up mine was full of rotting leaves etc . made one hell of a difference to my air con
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Quote Originally Posted by jaxouk View Post
    There's also more on this thread.
    http://forum.vectra-c.com/showthread...=aircon+stinks
    I posted a reply on this thread on page 11, which may also be of use. It helped mine no end.
    I've just read all your post in that thread John. I have Climate Control in my car so the AC is always running, right up until the engine is turned off, and I've never ever had any sort of musty, nasty smell in mine - either at start-up or any other time.
    From memory it seems to have only affected people with normal AC, as opposed to Climate Control, so I wonder if it's because they're not using the AC enough? If they only use it when it's hot then that's going to allow bacteria/bugs to sit and breed and make a stink, whilst with Climate Control it's always on so there's no moisture sat there long enough to get stagnant.
  1. ha ha i'm on u tube
    By woody in shetland in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2010, 20:45
  2. heater inlet/evaporator location for Expanding AC Cleaner
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 12th June 2009, 16:40
  3. you tube
    By The Gas Man in forum The 'Off Topic' room
    Last Post: 14th August 2008, 23:38
  4. you tube
    By The Gas Man in forum General Chat
    Last Post: 13th July 2008, 08:00
  5. Take The Tube Anyone?
    By Ben H in forum Comedy & Humour
    Last Post: 10th June 2006, 09:11
zafira evaporator
wheres the ac drain on a vectra c
vauxhall insignia air con drain tube
zafira air con drain
signum evaporator
vauxhall vectra drain holes site:www.vectra-c.com
vectra c air con evaporator site:www.vectra-c.com
opel astra h evaporator drain tube
vectra c ac drain
vectra c ac drainage
opel vectra c air conditioner drainage location
vauxhall insignia air conditioning drain
