Thread: urgent help needed!!!!!!!!!!
    Regular Member johnnyg's Avatar
    May 2007
    manchester
    Default urgent help needed!!!!!!!!!!
    as above driving home from the traffic centre tonight on comes the computer saying no dipped beam on right hand side no fog light same side no side light or front indicator on left side or high beam .looked in manual can not make head nor tail of it .i think a fuse has gone somewhere but dont know which one to look at
    cheers in advance
    May 2007
    manchester
    anybody help me with this please please
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    have you had a look in the fuse box on the end of the dash, to see if you can see anything blown ?????
    Midlands Mod Shop - NFFC.
    May 2007
    manchester
    yes looked in there mate nothing stands out .its got to be something stupid not all them bulbs can have blown or can they
    Jul 2006
    Mexico
    go and check the electrical plugs.....its not likely that all 4 are blown...so my guess is to check the root of the problem....the electrical plug.
    HTH
    Hertfordshire
    For multiple light warnings like that, it sounds more like a module has gone down or blown a fuse.
    But, I am pretty sure there is one module per corner of the car, so to have lights go out on both front sides at the same time is very odd.
    It is most unlikely to have two fuses blow or two modules crash out at the same time.
    Anyway, the fuses for the front light modules are in the fuse box under the bonnet, next to the battery.
    Can’t remember the numbers or ratings off the top of my head, but they are high ones, like 20, 25 or 30 amps.
    I’d start by checking them.
    Just to be clear here, are these just warnings or did the lights actually go out ?
    May 2007
    manchester
    oh they have gone out ok got six out altogether
    Hertfordshire
    Right, I'd start under the bonnet and go through all the fuses in the fuse box under there first.
    Very strange to have both sides go at once though, that doesn’t sound good.
    BTW, if you can find the front module fuses, pulling them out and powering down the modules for a few seconds, say 10 seconds to be sure, will reset the module if it has just flipped out. (they are listed in the handbook)
    Again, can’t believe both sides would do it at once, but it is possible if a bulb really causes a major short when it blows for it to trip the module, they are pretty hardy actually, and tend to shut themselves down before any major damage happens.
    If you can’t find a blown fuse, or don’t know which ones to pull, you can always disconnect the battery for a short while, this will have the same effect and reset a tripped module. (don’t forget you’ll need the radio code and have to reprogram windows etc) I can’t hang around any longer tonight, got an early start, off to bed now.
    May 2007
    manchester
    just an update really .had car in at the dealers today change ever bulb that the computer said had blown and nothing still the same .going back in on monday to have the modules looked at .where exactly are the modules ????
    Hertfordshire
    No idea m8, I know they are there, but never really looked for them.
  1. urgent help needed.
    By adierolfe in forum Electrical & ICE (including SatNav)
    Last Post: 25th June 2012, 09:53
  2. URGENT help needed
    By vectraedition100 in forum Engine & Drivetrain
    Last Post: 27th February 2012, 20:21
  3. urgent help needed?
    By webber446 in forum Engine & Drivetrain
    Last Post: 11th January 2012, 14:30
  4. urgent help needed >>>>>>
    By justin79 in forum Electrical & ICE (including SatNav)
    Last Post: 11th August 2011, 20:02
