Results 1 to 10 of 11
Thread: stronger rear springs
    lincolnshire
    Default stronger rear springs
    where can i buy stronger rear springs for my vectra cdti 150
    im planning on doing a bit of towing but the springs on my car at the mo are a tad soft
    thank you for any replies
    lincolnshire
    no one
    Full Member Big Sig's Avatar
    What about spring assisters?
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    rear springs on the vec's can be a bit 'weak' Had my boot loaded up with tools for about a year or so and once removed the boot stayed low and didnt come back up in height.. they stayed squashed
    maybe some stiffer springs like what would be fitted to GSi's or something? Maybe Gsi3.2 or Drinky could answer that one for ya
    May 2007
    Dartford
    Estate springs? Or are they they same as hatch / saloon?
    Jul 2006
    Think they're all the same TBH - certainly Eibach springs only have one spring rate for all engines/bodytypes.
    Could you see if springs from an Astravan or similar would fit?
    it sounds strange, but change to slightly lowered sports springs.....
    the elite has soft suspension anyway.. the GSi's have slightly stiffer springs and the sports one's are even stiffer again.. I tow with my GSi with -30mm eibachs fitted and it's like a rock.. very stable..
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    The Eibachs do come in different axle weights for the estate, But sadly it appears that this is only on the Fronts.
    The rears are all 1215 Kg
    As said spring assisters or perhaps another spring manufacturer do specific springs for towing Etc , I do know you can get them for the Mondeo Estate ..
    Dean
    Regular Member Drew's Avatar
    Sedgefield
    I tow a 4 birth caravan with a max weight of 1450kg (usually fully loaded) no problem, the important thing is not to over do the nose weight on the caravan/trailer. Max allowed is 75kg but stick to around 65-68 kgs and you will be fine. Use a block of wood on your bathroom scales to check. I have a no problem with my SRI estate on the standard springs it only dips about an inch and still handles well. Check tyre pressures are correct for towing aswell, mines on the optional 19s and the pressure has to increase quite a bit. I stick to 45PSI allround which sounds a lot but without lots of pressure you can damage the side walls.
    lincolnshire
    thank you all for your help
    i think a seb of eibach springs will have to be ordered
    again thank you
  1. sri rear springs
    By danluke1640 in forum Suspension, Wheels & Brakes
    Last Post: 13th June 2016, 08:21
  2. Rear Springs - which ones?
    By Di frost in forum Suspension, Wheels & Brakes
    Last Post: 7th May 2012, 20:55
  3. Stronger springs
    By tangoman in forum Suspension, Wheels & Brakes
    Last Post: 13th September 2011, 14:23
  4. Rear Springs
    By tony-1977 in forum Suspension, Wheels & Brakes
    Last Post: 11th May 2011, 12:56
  5. sri rear springs
    By 30ltr nutter in forum Parts for sale
    Last Post: 22nd March 2009, 23:45
astra van stronger rear springs
