Thread: Lambda fault codes
    Jan 2006
    Skynet HQ EMEC#5
    Default Lambda fault codes
    Thanks to Plasma's fault code diagnosis on Sunday after the spanner light appeared, I've just replaced the Lambda sensor.
    (I was a bit wary loosening it because Mark said on Sunday "don't break it in the manifold" )
    What I'm wondering is, I have disconnected the battery (been off about 1/2 hour now).
    Will this reset any fault code logged so that the ecu doesn't think there is a bad sensor in still??
    yep, it will reset the ecu's back to factory state, so any new faults will show and the old one's won't..
    Jan 2006
    Skynet HQ EMEC#5
    I tried searching the forum, but how long does the ECU take to 'learn', is it a few hundred miles??
    less..about 50 miles or so Ian..
    Jan 2006
    Skynet HQ EMEC#5
    Thank you Sir
  1. Fault Codes
    By Padster72 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd May 2012, 18:48
  2. lambda changed but more fault codes.
    By TimTay in forum Engine & Drivetrain
    Last Post: 12th June 2011, 19:11
  3. help with 2.2 dti fault codes
    By peadar in forum Engine & Drivetrain
    Last Post: 14th January 2011, 15:17
  4. Fault codes.. anyone help what they are?
    By blue estate in forum Engine & Drivetrain
    Last Post: 25th April 2010, 12:41
  5. Fault codes...
    By Stevie-B in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2009, 13:56
