Thread: Slight rattle noise...
    Regular Member Stevie-B's Avatar
    Mar 2007
    NI
    Default Slight rattle noise...
    Hi all,
    After having the front wheel hub fixed, I've noticed a slight rattle noise when pulling off in 1st. It sounds to me like the exhust is starting to go... (hav'nt jacked and checked yet).....
    If it is how much and what do I need to do regards the exhust system. My car is a 1.8LS by the way...
    Jan 2006
    Skynet HQ EMEC#5
    Before you start replacing exhausts, a guy at work had a rattle on his Vecta B when pulling off.
    I had a look underneath & the heat shield was hanging down.
    He fixed it in place....rattle gone
    Something worth checking
    Jul 2006
    Mexico
    Yeap take a peek first sounds like you have something loose as Mr. Ian said
    Mar 2007
    NI
    Thanks guy's....
    Yeah I'm a bit concerned as when the wheel hub unit was being replaced I asked the mech to check if the heat sheild or exhuast was okay and he said they were fine.....
    Looks like I'll need to jack her up and have a look.
  1. window slight noise
    By dbgb25 in forum Bodywork & Interior
    Last Post: 20th July 2011, 10:50
  2. slight rattle on first start up.
    By patch22 in forum Engine & Drivetrain
    Last Post: 17th June 2011, 21:03
  3. Slight Tapping Noise
    By spennny in forum Engine & Drivetrain
    Last Post: 28th March 2011, 21:03
  4. Slight rattle on gear change?
    By Signum-Steve in forum Engine & Drivetrain
    Last Post: 18th July 2010, 14:32
  5. Slight rattle front end...
    By Stevie-B in forum Engine & Drivetrain
    Last Post: 10th March 2008, 13:36
