Thread: Limp mode
    Regular Member dan1983's Avatar
    North London
    Default Limp mode
    Hi could someone tell me what this means and what happens.
    The engine management system (EMS) has lost communication with one or more sensors
    This normally means that sensor has failed and requires replacement
    Such sensors are either required or essential for the engine to run correctly
    However, the EMS can run in limp mode without the signals from the sensor and the EMS light will come on
    Typically the revs are limited to prevent engine damage
    Book the car in for diagnosis and repair as soon as possible
    North London
    cheers
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    has it happened to you car? could be something to do with the lambda probe if it has!!
    North London
    not sure cos it happened quite soon after i bought the car so dont know if im getting the performance i should
    It will also happen when a sensors detects a reading out of the expected range and will put the engine into limp mode to protect it i.e. the sensor would still be working perfectly and communicating fully with the EMS. A perfect example being a split boost hose - sensor detects an out of range reading so forces limp mode. Sensor working fine and communicating fully and detecting a physical problem. So it's not only due to a loss of communication/faulty sensor.
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    My only experience was in a TD hire car. You know for sure that it's happened - it was like driving a car with a little diesel engine and no turbo! If you are doubtful it sounds more like its just under-performing a bit for some other reason?
  1. Limp mode?
    By chrosty in forum Engine & Drivetrain
    Last Post: 18th April 2012, 12:35
  2. Limp mode help
    By neill in forum Engine & Drivetrain
    Last Post: 20th March 2012, 19:53
  3. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
  4. Limp mode
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2008, 10:34
  5. limp mode
    By vauxvec in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2008, 22:03
