Thread: Gear Change
    Regular Member amiddleton's Avatar
    May 2008
    Hull
    Default Gear Change
    I dont think its a problem just me getting used to a new car but when i change into 2nd gear if you dont get it right it feels like it jumps in and jerks a bit.
    Any one else
    Cheers.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Can't jumping in and jerking a bit.
    N Ireland
    noticing something similar with mine basically feels like the clutch isnt fully down annd the gears are just notchy. i might try a gearbox oil change and put in some higher spec oil but i really cant see it making much of a difference, this is probably my biggest gripe with my car trying to change gears quickly is just not fun just feels like its ripping the cogs apart.
    Northampton, UK
    I have this problem with my 54 plate signum design, when I pull away in 1st and rty to put it into 2nd, I have to be so girly and delicate or it screams and grinds away like I dont have the clutch down at all. It's really embarrassing if I time it wrong, look like a right newbie!
    Regular Member joules2.0t's Avatar
    surrey
    Trim : SRI
    Year : 53
    Not had that trouble, the gearbox could be better though.
    Check the clutch is bled correctly, uses the same reservoir as the brakes
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    gear box on diesel's are well known for be notchy , but you soon get udes to it
    Midlands Mod Shop - NFFC.
    May 2008
    Hull
    I have found it to be a big down side, i was unsure as i had a MG ZS previous and that was the most fun car ive ever had.
    Regular Member GoldenWonder's Avatar
    Durham
    I've always thought that was the biggest letdown on my car. A reasonably swift change from 1st to 2nd feels like I'm crunching it into gear!
    Tried getting the clutch bled but it didn't make any difference. I would lubricate the linkages but haven't got a clue how to!
    It does feel as if the clutch isn't fully released though.
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Quote Originally Posted by GoldenWonder View Post
    Mines not quite so bad, I would say more notchy than crunchy but it is a bit of a let down, especially when you have a Corsa/Astra as a loan car and the gear change is smooth as silk.
    N Ireland
    surely there has to be something the stealers can do about this issue. Think about it. say about 40,000 miles of the gears being crunched non stop.... how good will the gearbox be then.im gonna give the dealership a call during the week if they are open and see if there is anything that can be done for this.
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2017, 03:14
  2. 1.8 vvt gear change
    By davidpickard in forum Engine & Drivetrain
    Last Post: 12th December 2011, 12:16
  3. gear change
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2010, 09:31
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. change gear
    By aptoman in forum Engine & Drivetrain
    Last Post: 3rd June 2008, 23:16
