Results 1 to 2 of 2
Thread: Air con
    Regular Member steve1975l's Avatar
    Mar 2008
    Surrey
    Default Air con
    My girlfriends car needed the AC looking at as it wasn't working at all so I took it to someone I know. It turned out to have 0.140kg of coolant left in it. He did the bacterial stuff, uv etc and the vacuum test and filled it up with 0.580kg.
    I said mines working fine but you may as well check it. I thought the air was cold before, he took 0.340kg out and did his magic and now it is too cold. So if you use the AC as much as me as I suffer badly with hayfever a service is well worth it.
    Regular Member Matt's Avatar
    Feb 2008
    in a 3 bedroom house
    mine aint to clever might take it to someone before billing!
