Thread: A very sad day :(
    Regular Member EARLEY's Avatar
    Oct 2007
    Liverpool
    Default A very sad day :(
    I have discovered that my drivers window creeks when half open and my drivers seat squeeks and creeks
    its only a 56 plate its made me ****** annoyed and for a few moments i thought about getting rid
    any ideas on my window or even my seat?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by EARLEY View Post
    I don't know if it is true or not but the build quality of newer models compared to the older is not the best. Supposedly
    Gazza4
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    have you tried spraying wd40 on the window rubbers and on the springs on the seats
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    take it back to the dealer's imo mate, still under warranty so get them to sort it out
    Midlands Mod Shop - NFFC.
    Oct 2007
    Liverpool
    i was thinking about WD40 but to be honest i didnt fancy spraying that all over the seat having it drip on to my carpets etc. its not the window rubbers its the actual window
    Birmingham
    Quote Originally Posted by glynn View Post
    Dont do wd40, it did this on a vectra-b and it make it worse, take the panel off and grease the actual rollers and the bototm end of the window sliders, one each side, shoudl do the trick, worked for me!
    HTH
    Bye bye Vec B
    - Hello Siggy!
    Regular Member Karl's Avatar
    Sunderland
    its in warranty, do what I did, take it back and let them fit a new seat base and window motor....(had the same sounding fault on my 03 Dti)
    Regular Member moorlander's Avatar
    Apr 2008
    Staffordshire
    if its under warranty then take it back - esp for the seat. In regards to the window WD40 worked on my Vec-B, I bet thats all the stealers will do anyway...
    Ex-Staff Full Member Taffyopel's Avatar
    Oct 2007
    Horley, Surrey
    When you've got the window half way down to where you want it, just tap the 'Up' on the window switch so it takes the strain off the window regulator.
    Snowman, you got your ears on?
