Results 1 to 10 of 19
Thread: Drivers door keeps "clunking"
    Germany
    Default Drivers door keeps "clunking"
    When I open the drivers dooor of my Signum, if I open it more than half way, I hear a clunck noise. It is the same when I close it. If I only open it a bit and not to half way, no noise, Any ideas anyone ?
    Sounds like the check straps - little bar type things on the hinge edge that stop the door opening too far - need a bit of greasing.
    Wales
    Or if they are like mine need replacing
    Like Duncan said slap some grease on the bar and where it enters the door and work it in a little
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Sorry to , but mine does the same.
    To be honest it dont bother me but just curious as to what causes this clunk?
    It opens and closes fine, its just something I noticed?
    Would a bit of grease sort it?
    over....normal service can be resumed!
    Regular Member Karl's Avatar
    Sunderland
    Normally if you tighten it up the noise goes away (big torx bit required)
    Birmingham
    Quote Originally Posted by Karl View Post
    Is that on the door side or the post side? have big torx from doing my control arms..... !
    Germany
    Is this it ?
    If so what do i Tighten ?
    Birmingham
    Quote Originally Posted by chrish View Post
    Is this it ?
    Thats the bad boy!!!
    Germany
    Thanks Guys will get some grease in the morning......
    South east
    You need quite a lot of grease, and apply it as soon as you start hearing the noise - don't put up with it just because it's just a noise - untreated it will get worse and the door check strap will break within the door, leaving you with a door that doesn't stay open. This is a VERY common problem on Omegas, and although it's less frequent on Vectras due to GM (somewhat) learning from their mistakes, if you've started to hear the noise then you're already closer to having a broken check strap than you would want to be, so take action now.
  1. Replies: 32
    Last Post: 2nd January 2013, 02:18
  2. Interior door sills and "b" pillar removal
    By si_hoss in forum Bodywork & Interior
    Last Post: 12th May 2011, 12:25
  3. central locking /"door open" Help!
    By tommoturbo in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2009, 07:22
  4. Unlocking door "press once" hack ?
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 16th September 2007, 19:54
  5. Replies: 2
    Last Post: 2nd December 2006, 22:47
vectra c clunk drivers door
vectra c door clunking
vectra drivers door clunking when opened
vectra clunking door
