I have found the flap and felt down into the gap and found only 1 large(ish) oval shaped hole. Could feel down into the hole. Didn't seem too full of anything. Maybe best look with a torch in the morning
If you look beneath the oval hole there should be a rubber tube where the water drains out. I believe its somewhere behind the ABS module/servo thingy which is behind the battery. It gets clogged up with dirt and leaveves etc. You should be able to clean it out with your finger. Hope this helps
I had the same problem last year with my 3.2 V6. Main stealers told me to take it to a windscreen fitters. OK, I said. What could they do, I thought ????. Hello Sir, How can I help you?? Told him of the problem. Easy he said. As others have said, after clearing the drains of leaves etc, he cut off the narrow part of the rubber pipe, thus widening the outflow !! Simple eh.Pair of scissors needed! Raid the wifes sewing box !!!!!
