Thread: Rear Control Arms & Tracking
    Birmingham
    Default Rear Control Arms & Tracking
    Very Quick one for you guys, over the last two weeks I have replaced my Trailing Arm Damper Bush's, ARB bushes and my Upper Rear Control Arms, will the car now need to be re-tracked?
    I have only ahd it done about 2 months ago, but didnt know about the arms repalcement then?
    I havent noticed the car feeling any different bit does it knock it out?
    Also, I will be changing 2 rear tyres soon, if needs tracking, should I change the tyres before or after the tracking?
    Thanks.
    Bye bye Vec B
    - Hello Siggy!
    Mileage : 000
    I would have thought it best to get them done at the same itme then you know they al both ok.
    Jan 2006
    Skynet HQ EMEC#5
    As Ed has said, best to get it done.
    I replaced my upper rear arms then got it all aligned.
    There is no guarantee that the bars dimensions are exactly the same.
    HTH
    Jul 2006
    and
    You need to have the alignment checked EVERY time you do anything to the suspension.
    East Midlands
    Quote Originally Posted by vauxmang View Post
    Thanks.
    ?Did your car need tracking up m8...i asked a mate who's a tyre fitter for National Tyres...he said no need to as the track setting has not been altered.
    Nicking Ya Dinner.
    Quote Originally Posted by macdad View Post
    Thats how I saw it as well, caution says have it checked anyway.
    Birmingham
    In all honesty, it can affect it as you are tugging on spanners and what not and that can knock it out.
    Anyway, ironically, by sorting the back arms out, it actually knocked out my front settings.
    When it got on the laser checker, it showed as the front was pulling inwards and the back was going a different way, but by adjusting the front it automatically pulled the back into line!
    Get it done mate, for the cost of it its well worth it!
    I swear by tracking as it saves your tyres and probably your life on a wet day and a pot hole!
    Get it done mate!
    Bye bye Vec B
    - Hello Siggy!
    Regular Member old cruiser's Avatar
    slough
    That I can believe mate, as due to the work you have done you would have almost certainly altered the Thrust Angle and this angle is crucial to getting the geometry correct, as correct front tracking can only truly be measured against the Thrust angle and the setting of rears, unfortunately a lot of centres claiming to do 4-wheel alignment appear to be clueless as to what is really going on and if you ask them what have they tracked the front against, you often get the answer 'what do you mean Sir' and in my opinion that answers it all!!
    Cheers Pete
    Birmingham
    Exactly!! Well said mate! Where I go the guy shows you what the angles were, then sets it up and shows what they are now!
    Bye bye Vec B
    - Hello Siggy!
  1. Rear Control Arms
    By thegoldenbullet in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2011, 18:33
  2. Different Rear Control Arms?
    By ChrisBilly in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2010, 15:26
  3. Rear control arms and ARBs
    By axelf in forum Suspension, Wheels & Brakes
    Last Post: 29th April 2010, 13:52
  4. Rear control arms
    By parsco in forum Handling & Braking
    Last Post: 7th July 2009, 09:13
