Thread: Signum CDTI 150 Judder
    Jan 2008
    telford
    confused Signum CDTI 150 Judder
    Hi
    I have a signum 150cdti with 50k on it.
    I have hade the manifold replaced under waranty, swirlvalve failure.
    I recently fitted a Caterman box and seems to be good.
    Only problem is when the car is warm and I drive on part throttle is seems to Judder/ miss fire. There are no problems when I boot it only on part throttle arround 2-3k rpm, no spanner lights present.
    When I remove the box it seems to go away, become less .
    Has anyone else had the same problem.
    Any advice would be welcome.
    wade
    Jul 2006
    EGR valve I reckon.
    There's a good How2 for cleaning it on here if it's out of warranty, otherwise get it back into the dealer for them to do it.
    HTH
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Quote Originally Posted by wadep509 View Post
    Hi
    Only problem is when the car is warm and I drive on part throttle is seems to Judder/ miss fire. There are no problems when I boot it only on part throttle arround 2-3k rpm,wade
    So what happens if you unfit the caterman box & go for a drive ?? If the problem is still there, then the box is not to blame, Undo the last change first to help with diagnosis.
    Dean
    Jan 2008
    West Wales
    My understanding is that the Caterman and most tuning boxes increase fuel supply / pressure. So when under low RPM but under load the car may be over fueling a little. If this is the case it just means you have to change down a gear to raise the rpm or boot it!.
    Not sure if this helps or not but that is my understanding. Downside of more fuel / pressure.
    Anyone else had this issue with tuning box fitted?
    Rgs
    Bobby
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I have had some lurching anf juddering with boxes in some setups, changing the level on the box has sorted it though in the past. If you have an adjustable box then have a twidle and see if it goes.
    Regular Member Karl's Avatar
    Sunderland
    I must admit mine has done this a few times (kinda a littel stutter as it were). I put it down to crap diesel so have ran on V power diesel for a while, doesn't seem to happen with that in. (neither should it for the cost!)
    Belfast
    Yeah, some bad diesel will do that with mine, especially as mine's a little tweaked so doesn't like bad diesel at all. A bit of Millers Power Sport 4 lashed in usually cures the issue.
    Jan 2008
    telford
    Had the car in to Vauxhall today.
    They have replaced the EGR and said to see if that cures it.
    They did say that the problem I had is know about by VX Tech and they are waiting for a software update to be released to fix it.
    Jun 2011
    Fife, Scotland
    My 150cdti did this with my DTUK tuning box. Even sometimes on cruise control at 70mph. As if I lifted my foot off for a second. It gradually got worse, so I removed the box. Problem went away. My thinking is that the tuning box put strain on the fuel system, highlighting/creating a problem. If I wanted a fast car - I wouldn't have bought a vectra. It is not that slow/bad standard(127k miles).
  1. V6 cdti judder
    By Phill signum in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2012, 17:25
  2. CDTI 150 Judder
    By tatters40 in forum Vectra C / Signum Car Chat
    Last Post: 3rd May 2012, 23:24
  3. 1.9 CDTI 120 Hesitation Judder.
    By CDTI120SXI in forum Engine & Drivetrain
    Last Post: 8th July 2011, 17:45
  4. 1.9 CDTI Judder in 1st
    By robdd1 in forum Engine & Drivetrain
    Last Post: 24th December 2010, 16:05
  5. Vectra Cdti 1.9 Clutch Judder
    By CHRISSMART41 in forum Engine & Drivetrain
    Last Post: 14th October 2007, 11:15
