Results 1 to 5 of 5
Thread: Strange noise - rear near side
    May 2007
    Cheshire
    Default Strange noise - rear near side
    1.9cdti 150 auto estate.
    Strange noise from rear near side. Biit of a back ground noise when driving at any speeds - especially around town at 30 / 40 mph. First few times, I thought that there was a plane overhead.
    Also, only every now and then, there is a bit of a grinding noise coming fromt he same place at slow speed braking.
    The car has only done 25,000 miles. it was serviced only last month, and no mention was made of brake wear etc. Also, i would have expected the fronts to go first ?
    I know i should take it to the dealers, but I was just wondring if anyone had any ideas.
    Jan 2007
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    could be brakes binding mate, rear's dont last long at all on some car's..........could also be the wheel bearing grinding but i would favor the brakes, deffo get it checked out if i were you though
    Regular Member parapaul's Avatar
    Jul 2006
    grinding noise is almost definitely worn brakes, and for some reason some vecs eat them. Your other noise could well be binding, which would explain the early wear...
    Regular Member BlueRob's Avatar
    Jul 2006
    Mexico
    My best guess would be a funny wheel bearing as Ditchp said
    South east
    With Vectra-C's and Signums, if you ever come to the conclusion that your rear bearings are shot, it's often (not always) in fact the rear tyres that are the cause.
  1. help strange noise after cleaning out side throttle body
    By 6009tristanb in forum Engine & Drivetrain
    Last Post: 23rd February 2012, 17:52
  2. strange noise from rear drivers side
    By chris_20 in forum Engine & Drivetrain
    Last Post: 27th February 2010, 21:47
  3. Noise from rear - strange remedy
    By apetryne in forum Suspension, Wheels & Brakes
    Last Post: 21st May 2009, 17:19
  4. Strange Noise from Signum Rear End
    By powelly1592 in forum Suspension, Wheels & Brakes
    Last Post: 4th May 2009, 01:34
  5. strange noise from rear????
    By dave16v in forum Suspension, Wheels & Brakes
    Last Post: 23rd May 2008, 22:21
