Results 1 to 10 of 13
Thread: help, signum owners...
    Nov 2007
    bournemouth
    Angry help, signum owners...
    Well, took my car into the dealers friday last week to sort out a few
    niggles..... After lots of checks on my 'bearing' sound on the back they
    blamed my tyres, just like markGSi said, however taking them off i was
    able to see that the camber is miles out. With the irmscher suspension
    and 19" wheels on the wear on both inside edges of the tyres is unreal
    after 10K miles. Now it cant be the wheels surely, afterall they were a
    factory option, and the suspension iss the irmy full kit and only 30mm?!!?
    Does anyone else have this problem?? i am going to get through rear tyres 3 times a year?!?! i was expecting it slightly but my tyres have a 5mm diffence edge to edge!!
    Full Member Big Sig's Avatar
    Have you had the tracking and alignment fully checked?
    Jul 2006
    Yep, rear camber is a big problem on the vec c and signum. Don't know whether you'd be able to get the dealers to do it or not, but you need proper 4 wheel alignment done, especially if it's been lowered.
    www.alignmycar.co.uk
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    even though you have lowered it by 30mm the camber angel can still be out and wear the tyres very badly and with the tyres it can give off a bearing noise
    p.s have you got the info for the s/s
    After i lowered Mrs GSi's i had the tracking and camber set on all 4 wheels as the backs were way out of camber.. a full 3 degress.. and they ate the inners..
    Same happened when i dropped the GSi, but that still eats tyres as even thou it is adjusted as far as the adjusters will take it, it still runs big negative camber on the rear.. a pair on the rear last about 10,000 miles..
    go to your local 'HUNTER' centre.. they can align it properly.
    Quote Originally Posted by parapaul View Post
    i see folks remember my links now as well.......
    Nov 2007
    bournemouth
    i meant to say that i had it all adjusted when i had the suspension fitted, could it of changed as the suspension settled??
    Regular Member shan's Avatar
    I remember the wheels you have were in quite as state before you had them refurbed.
    If you had the alignment done, and it was done correct.
    Maybe the wheels are at fault ??????????
    I'd get them check to see if they are bent/buckled.
    Quote Originally Posted by TIMMAH View Post
    as a rule, you're ( the fitter ) supposed to do the suspension work, drive the car around a bit to let it settle, then after it has had a chance to work out all it's new built in 'forces' and it's back to where it wants to sit, Then track it.. you'd be surprised the number of places that just whack on the targets and set it up anyhow....before it's had chance to settle..
    Personally.. i'd get it tracked again, and while you are there, just ask them to rebalance your wheels....while it's being done you can watch the wheel rim and see if they are buckled like SHAN SAID..
    Wirral / ellesmere port
    10 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    when irmscher suspension kits are fitted to any car then the
    tracking,camber,toe in/out etc must be adjusted accordingly so
    thats more than likely ya problem with uneven wear on ya tyres
  1. Signum owners..................
    By Shogun in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2011, 21:27
  2. Signum owners plz help
    By s2yob in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2011, 22:31
  3. Signum owners...
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2010, 17:57
  4. Signum Owners
    By bgm46 in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2009, 09:10
  5. Signum owners
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2007, 19:28
