Thread: bsr problem
    Regular Member Whippy's Avatar
    Oct 2007
    wirral
    Default bsr problem
    my unit keeps coming up as "locked, please syncronize again." after displaying a "not for this car" message.
    i've tried multiple syncs but to no avail.
    the device remains locked after each sync.
    i really wasn't expecting this much trouble...
    anyone know if there's a way of resetting the unit or do i have to wait for office hours at bsr
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Yep u have to wait for BSR but do it online at http://en.bsr.se/support/ which is Sweden. You wont get any help for your problem in the UK as they will direct you to Sweden. I had the same issue and they told me it was because I had failed to put the ignition on whcih is the only way this fault occurs. But i did do yet it still happened, but anyways they sorted it
    Full Member Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Hi whipply, I had this happen to mine the 1st week of june, I spoke to Justin about it he then spoke to BSR and they told him it was because i may have had the key in the 1st position and not the 2nd position (all lights on dash on), If you Phone Justin he will get it reset with BSR for You, you'll then have to resync it and it should be ok..
    Oct 2007
    wirral
    someone's working late in sweden.....
    they unlocked it but it's done it again.
    i can't even get to the stage of reading the car.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    ok then may be a fault with the remap, mine had an error in it and had to be alter before it would go on. Have u made sure everything was switched off, heater blower, radio and anyhting else plus all the doors are closed? BSR Sweden will work with you to sort it online so keep at it as it is worth it in the end!!!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Thinking of it the vin number may be wrong in the programmer which would give that error
    Oct 2007
    wirral
    vin is correct but it says it's using the OPS one on the sync history, not the cars which i find strange?
    i'll just have to bear with them then by the sound of it.
    ta peeps.
    Oct 2007
    wirral
    i've been away working all week again. (sods law)
    bsr got back in touch and it's all done.
    WOW, what a difference
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    what was the problem then mate?
    Oct 2007
    wirral
    looks like it just enjoyed locking up.
    they reset everything, i re-synced and it all started working.
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
