Thread: Problems with heater speeds
    Stoke on Trent
    Default Problems with heater speeds
    Hi all
    I am a newbie and am after some help. I have the common problem of the fan only working on speed 4. I have searched this site and found the problem was the resistor and have replaced this and was blessed with a fan for 1 whole day.
    Now I am back to no fan or full speed. What can I do??
    Sig 27
    Regular Member benny's Avatar
    Feb 2006
    dudley
    replace the resister again and also replace the heater motor ....
    May 2008
    fife
    Quote Originally Posted by benny View Post
    were is the resistor located as i have the same problem
    Admin plasma's Avatar
    On the Forum
    287 Post(s)
    Engine : 150
    Mileage : 74000
    Suspect reason benny is saying to replace the motor too is probably the water that dripped down through the pollen filter also corroded the motor itself and was struggling to turn which caused the new resistor pack to burn out.
    Quote Originally Posted by stj View Post
    See the following post by ijg
    http://www.vectra-c.com/forum/showth...t=21620&page=3
    Quote Originally Posted by plasma View Post
    bang on dad......
    when you get a new motor, drill a tiny 2mm hole at the lowpoint of the housing to drain any water out that collects again..
    Stoke on Trent
    thanks for the help sort of suspected from other threads but wanted to see if thier was another way.
    Any ideas how much a new motor will cost?
    Any ideas how much that will set me back with VX doing the work??!!
    Thanks for the help.
    Nov 2010
    dudley
    my heater only works on 4 and windscreen not on1 2 3 i have checked the fuses and the resister works ok any idears thanks
    Quote Originally Posted by pete w View Post
    How did you check the resistor? The classic signs of a failed resistor is that the speed will only work on setting 4.
  1. Is it the blue relay that controls heater fan speeds 1-3
    By marky2027 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2012, 13:44
  2. Heater Fan not working on speed 1, Speeds 2,3,4 ok
    By lehapau in forum Electrical & ICE (including SatNav)
    Last Post: 9th October 2011, 20:02
  3. heater problems
    By pete w in forum Bodywork & Interior
    Last Post: 12th December 2010, 21:28
  4. heater problems!!
    By dazza2393 in forum Electrical & ICE (including SatNav)
    Last Post: 11th July 2010, 08:32
  5. Heater Fan Problems
    By kel123 in forum Electrical & ICE (including SatNav)
    Last Post: 9th March 2010, 12:00
