Thread: any tips on how to cut the rear valance to show my exhaust tips
    Regular Member eaglepva's Avatar
    Up North
    Default any tips on how to cut the rear valance to show my exhaust tips
    Getting my new exhaust fitted tomorow but i havent got the new rear valance with the exhaust cut outs from vaxuahall yet so im going to cut my existing valance untill new one gets delivered.
    But what do i use to cut it any tips appreciated.
    Cars a signum.
    Regular Member DesignforLife's Avatar
    Lancashire
    Thumbs up
    Be very careful, this is how I did mine:
    * If you look there should be a pattern on the inside of the valance/ skirt.
    Method 1: Use a sharp stanley knife and carefully cut from the inside - starting from one side to the other. - Sand any edges left from cutting.
    Method 2: Use a Coping saw blade or Hack saw blade and cut around from underneath - being very careful.
    Top Tips - Use Masking tape on the outside/ painted areas - to protect against cracking or slips. Take your time!
    HTH - Matt
    Jul 2006
    Mexico
    God I cut mine to show the twins in the back after I installed some new chrome tips....the bad new is that I don't seem to find the thread with the process and the pics
    Admin can you help to find my thread, so the mate here can have some reference ?
    Jul 2006
    Mexico
    Forget it Admin I found my self
    Here you go mate....hope that helps on any pointers on how to cut the plastic skirt...(jump to post 16)
    http://forum.vectra-c.com/showthread...ht=tips&page=2
    Regular Member Gripper's Avatar
    Middle Wallop Andover
    Buy a Dremmel. Easy to hold and keep steady. It comes with a wide selection of cutting tools that are perfect for the job you are on about. I used one to cut my bumper and there were no problems.
    Jul 2006
    Mexico
    is what I used
    May 2007
    Dartford
    Rob, you said that you had the exhausts that point down (instead of going straight towards the back), so did you cut that part off or did you fit the tips straight over them? Cheers!
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    method 36584: As your p***ed off with thinking of ways of cutting it, Kick it until it breaks a hole large enough for your exhausts
  1. Exhaust tips........
    By scotty84 in forum Styling
    Last Post: 26th June 2011, 12:01
  2. For Sale: Exhaust tips
    By soulman in forum Parts for sale
    Last Post: 7th June 2011, 21:59
  3. Exhaust tips
    By boodoo warrior in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2011, 19:52
  4. MIJ Exhaust Tips
    By Aidi in forum Styling
    Last Post: 22nd January 2011, 11:43
  5. Rear exhaust tips
    By winty234 in forum Styling
    Last Post: 4th August 2010, 10:08
