Results 1 to 10 of 17
Thread: Oil
    Regular Member cpt slow's Avatar
    In a house
    Default Oil
    Does anyone know what Gearbox oil must be used in the 1.8 xel engines gearbox. Its a five speed manual , seems im getting a rattle when the engine is hot . A normal drive for 200 or 300 miles doesnt rattle . This is on idle only with the feet off the clutch pedal , push in the pedal and the noise dissapears. Someone told me it might be the wrong gearbox oil used and when very hot and gears used very regularly the oil is loosing its power ???????
    Regular Member richardg3.2's Avatar
    Hull
    Sounds like it could be clutch release bearing.
    In a house
    Hmmm maybe , but only when happens when the gears have been used a lot around town driving . Very quiet when cold .
    Don't quote me, but the oil used to be Dextron ii..
    But I'd point at the release bearing as well, did they change it when you had the gearbox replaced?? losing power and the rattle makes me think the clutch could be on it's way.. More likely than the oil mate..
    In a house
    not loosing power , just a damned rattle . Its doing my brain in now . Yes they changed the release bearing when gearbox done .
    Is the gearbox still under warranty?
    In a house
    not now warranty is out now by about 4 months , they only gave me a 6 month one .
    In a house
    just wondering on getting a gearbox from a breakers yard , there seems to be a few Vectra C`s breaking around now . Or sell the thing and get a Mondeo ?
    Fraud's ain't much better... The only ford owner in our family swears he'll never buy another..
    If you could get a unit you could test, or a unit from a specialist dismantler ( who usually check them before sale), this would probably be a good route. Just sounds a lot like box more than oil to me.. If the rattle cease's when you load the clutch by pressing the pedal then it's either clutch or gearbox bearings IMO.. Round town 1st/2nd/3rd get a pasting, on a run you're in 5th.. either ends of the gear cluster.. Run this past techwolf , he'd prob have a better idea, or he may have seen this before..
    In a house
    damned car its one thing after another now .
