Thread: inlet manifold again?? surely not
    sheffield
    Default inlet manifold again?? surely not
    Hi Guys,as posted on here sometime back I had my Inlet manifold replaced on my Siggy 1.9cdti after initially coming up with the "repair for a quid" which worked well for 6k miles.
    It was changed at 82k and now done 113k and the dreaded spanner light and limp mode has started to reoccur today under exactly same circumstances i.e cruising at 70 and then limp mode which is what it did before with old design manifold!!
    Had a look and the linkage is still in place so not that and she's been idling lumpy at times over the last two weeks which it did before! Please some one tell me its not the ****** manifold again!!
    did notice that there were some splits in the small vac hoses at the front of the engine, maybe that could be it??
    as usual will be very grateful for any ideas before venturing to the stealers!
    pete mc
    TBH, it could be so many things.. i'd be surprised if it was the manifold again thou.. a session on a code reader is really whats needed, but if you've got split hoses they will need fixing first..
    Regular Member installer's Avatar
    Nottingham
    Could be I`m afraid.When was it replaced?But as the vec guru said could well be many other things.
    read this thread,post 9
    http://www.vectra-c.com/forum/showthread.php?t=51814
    sheffield
    It was replaced 15th November last year so as I paid some towards it i reckon should be still under warranty 12 months on parts is it??
    done 30k miles though since then!
    would'nt have thought new design manifold would pack up after 30k of mostly motorway drivin?
    pete
    if the part was fitted by a VX agent and you paid then you should receive a warranty on it..all you can do is ask..
    have you had it diagnosed yet?..
    sheffield
    Hi Ya,
    Not had it looked at yet as the old girl is stuck at Manchester airport as I have had to fly out to Ireland on a job!
    The job was done back in November last year at VX dealers in sheffield and interestingly one of their guys told me I should always pay something toward a repair as that way I have some come back cos if VX pay for it all they can say tough!
    So paid 20% for manifold.
    Now I have just remembered that I did the old EGR cleaning jobby 2 months ago following the guide on here which worked wonders but what if i did something wrong? what happens if ,say the EGR valve gets stuck shut? would this cause a fault code and hence limp mode?
    just wondering? will whip it off again when I get home and it is the original EGR which has now done 113k miles!
    a stuck orfailed EGR will deffo flag up fault codes and limp home..... well work a look inside it..
    sheffield
    Cheers GSi,
    Will report back on findings,it is a bit of a coincidence that this has happened so soon after playing around with the EGR which was in a terrible state!
    pete
    sheffield
    Default sorted prob
    well sorted the prob guys and it turned out to be a small vac hose on top of the vac pump, it had split round the back where I couldn't see it!
    new bit of hose and no more spanner lights and limp!
    still got a slight prob though and thats this slightly lumpy idle at start up either hot or cold only lasts for about ten seconds and if ya drive off straight away I dont even see it, its odd? and other than that the old girl drives like new even with 114k on the clock.
    pete mc
  1. inlet manifold
    By spidermonkey in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2011, 22:07
  2. 1.9 150 Inlet Manifold..
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 18th July 2011, 20:29
  3. Inlet Manifold
    By topcat850 in forum Engine & Drivetrain
    Last Post: 13th November 2009, 14:33
  4. New Inlet manifold?
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 8th November 2009, 23:06
  5. Inlet manifold/oil
    By the-wizard in forum Engine & Drivetrain
    Last Post: 3rd November 2009, 19:11
