Results 1 to 10 of 14
Thread: 2.8T - which engine?
    Jul 2006
    Question 2.8T - which engine?
    Z28NET...Z28NEL...Z28LET?
    Right. Which of these engines corresponds to...
    230PS / 250PS / VXR 280PS?
    The reason I'm asking - the dealer I'm buying mine from says the engine in mine is the NET and therefore the 250PS version, and that the LET is the lower 230PS version. Is that right? And apart from checking the VIN, is there any easy way of telling them apart visually?
    Ta
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    The vin plate on the door pillar, the 230 is 169kw.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Z28NEL = 230 ps
    Z28NET = 250 ps
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Both engines are effectively the same lump which I read was originally developed by Holden in Australia. The 'N' in 'Z28NET' and 'Z28NEL' refers to the compression ratio which is higher than the those that end in 'LET/LER/LEH'. The 'L' in 'Z28NEL' means it a lower-power version of the 'Z28NET'.
    If Craig has a 230PS version, then I would imagine it could be re-programmed to a 250PS version. VX would charge the earth to do it, I shouldn't wonder.
    BSR do a plug n play for the 2.8T..
    Jul 2006
    Quote Originally Posted by sig63 View Post
    Z28NEL = 230 ps
    Z28NET = 250 ps
    cheers
    Quote Originally Posted by parapaul View Post
    ...apart from checking the VIN, is there any easy way of telling them apart visually?
    Ta
    Anyone?
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    acording to TOTAL VAUXHALLS bit in the back THE V FILES the engine number's for the vxr are.....
    VXR 05 - Z28NET 252 bhp 262 torque...2798cc
    VXR 06 - Z28NET 277 bhp 280 torque...2798cc
    doesn't mention any other car with the same lump though.....
    Midlands Mod Shop - NFFC.
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : SRI NAV XP
    Mileage : 72K
    Silly me. Of course. Forgot it was 'BSRable'.
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : SRI NAV XP
    Mileage : 72K
    Quote Originally Posted by ditchp View Post
    Looks like the VXR is a 'tweaked' Z28NET then.
    all 225's are Z28NEL.....
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
z28nel swap
